Game's on! Ultimate Ecomodder Fuel Economy Challenge
You may already be a participant, and didn't even know it... :p
In... The Ultimate Ecomodder Challenge To keep things new and fresh on the site we’ve decided to start a fun contest to see who is the Ultimate Ecomodder! We’ve selected 16 ecomodders to play in this tournament and all they need to do to participate is to continue pulling great mpg’s while keeping their fuel logs current. If you didn’t get selected don’t worry…we’ll give you a chance in the next contest! FYI, Matt Herring spearheaded the challenge idea, and volunteered to act as the go-to guy / primary referee. Thanks, Matt! Here’s how it works:
Here’s our First Round Matchups: * I_Am_Socket (Skeeter ’05 Corolla LE) vs. Tasdrouille (The Truck-Mine ’99 A3 Jetta TDI)…+23.12 adjustment for I_Am_SocketResults will be posted here as they occur and round matchups will also be posted so you can track the results. Good luck fellas! |
1 Attachment(s)
Here's an excel spreadsheet of the tourney bracket if you want to follow along!
A couple notes from the ref: * I_Am_Socket is getting +23.12 in his first round matchup with Tasdrouille (is incorrectly noted as +mpg for Tasdrouille in original message)...sorry Tas...can't make it that easy for you! * cfg83 updated his fuel log on 11/18 with a fill up from 11/17 so that entry does not count in the tournament as the tourney started on 11/18. His next fuel log entry will be his first round tank vs. Tango Charlie. |
I JUST filled up......... but I haven't added it to my fuel log yet... should I put it in right now, and then that will be my score for this round?
Oh, and this is an AWESOME idea! |
We'll allow the next tank to be your first round tank...make it a good one! Just make sure you fill out your fuel log for the tank you just completed so we know which tank is your first round tank.
Another thing I just noticed, (and I'm not trying to be picky or anything), but if you look at Binger's fuel log... he has several VERY low entries, and then his last 6 (approx. 60-days) have been well over his 90-day... I guess I'm just saying that even if he gets considerably lower MPG than those last 6 tanks, he will still be well above his 90-day, whereas I have been getting 20-23mpg since April.
I'm not trying to be negative or anything, but it seems like I don't have a chance. Does all that make sense? |
Binger has acceptable fuel entries to qualify for this contest. One of the only rules is at least a 5 gallon fillup (which he is well over in his fuel log entries and he's been consistent with 6-10 gallon fillups all along). His 90 day avg. has been improved recently due to new air dam and increased psi which is the reason we're all on ecomodder.
On your side it looks like he has a new job that is only 3 miles from his house so short trips in frigid Omaha, NE might hurt his FE. Plus...you're getting almost 16 mpg handicap...and you have a whole tank to make it a good one...maybe he's already halfway through his tank when finding out about this contest??? Good luck Sean T! |
Ohhhh, I like it!
cfg83, you're mine, sucka. You with the pretty silver wheels... All 'look at me, I get over 40mpg'...yeah...yer goin' DOWN, pal... Oh, wait. Is trash talking allowed? :D |
I have not entered any fuel logs since the weather got cold and I just filled up today, so what should I enter?
Tango -
I like your matchup with cfg...interested to see if the Vibe can keep up with the Saturn Wagon (or at least stay within 4.2 mpg). It's Indiana vs. SoCal! Good luck! |
