Gas goes up, Car weight goes down
So since gas is getting so high lately and I deliver in my car, I decided to get my car to loose some weight... Here is whats going on so far.
Weight of each thing is based on using both of the scales we have at home, nothing fancy so I cant say its to the oz but it should be close measurements... 10.6 lbs..... Taking out the bottom part of the back seat 23.6 lbs..... Taking out the top part of the back seat 07.4 lbs..... Taking out the piece that covers the spare tire 03.6 lbs..... Taking out the rear floor mats 02.8 lbs..... Taking out the giant jumper cables I got 26.4 lbs..... Taking out the spare tire 00.5 lbs..... Random crap sitting in car I didn't need 02.3 lbs..... Passenger side-side view mirror (Electric) -------- 77.2 lbs Total Will update any of this if I pull more stuff Also: Geez, nothing like gas going up a ton to make you start watching that SGII like I hawk again eh? haha |
I always like to see weights posted for a weight reduction. If you don't normally carry a passenger, you can take out that seat, too. It goes back in quickly, should you need it.
I'm considering a quick release for the partner seat on my golf... None ever ride with me, so it's extra weight/less space.
Some other things you can save weight with:
Spare/tools -replace with plug kit and small air compressor Rubber foot pads on the pedals Fixed glass - poly-acrylic Seats: suspension seat rebuild Exhaust: pre-muffler/resonator if equipped Cut the plastic behind your air dam There's more, but some involves cutting/drilling parts Urethane is typically lighter than rubber, for bushings, but dont go out of your way to replace ones that don't need it. |
With effective anticipation of lights & stop signs (i.e. not using your brakes), weight is only a second-order MPG effect. You need a longer pulse but you get a longer glide.
Some members of this forum have reported higher MPG with increased weight, because it fits the pulse & glide cycles of their commute better. Aerodynamics, tire rolling resistance, and engine efficiency are first-order effects. |
And yet still, it's fun to see just how light you can make a car without making it structurally unsafe.
I miss my 1989 CRX Si so day-um bad, I miss only weighing like 2100 pounds :D This car weights like 2900 so If I can loose some of that and get closer to the CRX im happy... Too bad I cant throw a 1.5 liter engine in this car :( |
