EcoModder.com
-   -   Gas stations without ethanol (https://ecomodder.com/forum/showthread.php/gas-stations-without-ethanol-14093.html)
evilskillit 08-03-2010 02:06 PM
I prefer not to get ethanol gas if I can help it. It seems QT (the local fill up station of choice is running ethanol, possibly in every grade of fuel). Does anybody know of a sure fire way to find out who does and doesn't add ethanol? Is it required by law to be posted on the pump, is it that simple?
I live in the kansas city area. If any of you know which ones do and don't add ethanol clue me in and I'll try to stop there more often. Also I use premium fuel fwiw. Maybe some places add it to one grade and not another? I know of one gas station that advertises that they do such a thing...
RobertSmalls 08-03-2010 02:12 PM
Here's what I know about it: http://ecomodder.com/forum/showthrea...gas-13576.html
evilskillit 08-03-2010 02:31 PM
Ugh, Missouri REQUIRES 10% ethanol in all gas except that rated 91 octane or higher. Tho it still may be blended in and no visual indication is required.
KS is just as bad except they don't require the ethanol in the gas, but they don't have to tell you if its there. Sucks to live here if you care about that sort of thing.
ecofreak 08-03-2010 05:11 PM
Rather have my gas stretched with something local than burning more oil in the long run through transport.
Guys, unless you're competing, or doing the best run you can, you must look at the big picture. Better mileage or better impact?
evilskillit 08-03-2010 11:49 PM
I suppose so, but it burns me when I pay the same per gallon as fuel that gives you better mpg. Plus until they switch away from something other than corn the whole situation is pretty screwed up anyways with the govt paying farmers NOT to grow corn because they're throwing it away, then they start making ethanol out of it and the price skyrockets driving up the price of corn, cornmeal, cornbread, corn syrup and other things and now we're paying an inflated price for the corn we paid them not to grow in the first place. And its not even that great for ethanol production... :end rant:
Plus even if my car is ok running it, and I don't 100% know that it is. What about my mower, did mower designers even consider this 3 or 4 years ago? Who really knows. Etc for other applications. I know it's shelf life is diminished. They don't even sell it in marinas because its hydroscopic.
redpoint5 08-04-2010 02:32 PM
Oregon and I believe WA require 10% ethanol in the gas. I watched my mileage plummet when this change occurred. Thanks for the link Robert! I might have to check out the CFN nearby to see if their gas prices are reasonable, and without ethanol.
I am not sufficiently satisfied that burning corn ethanol is environmentally advantageous. The evidence seems to suggest just the opposite.
Most likely the ethanol in my gas is not local. Furthermore a lot of fuel is spent growing corn and fertilizing. My hunch is that if it was more environmentally friendly to use ethanol as a fuel, it would also be cheaper than gas (per unit of energy, and minus all subsidies).
SoobieOut 12-23-2010 04:10 AM
[IMG]http://ecomodder.com/forum/member-mo...hanol-free.jpg[/IMG]
Took this photo 2 weeks ago in Hawaii. Seems that they are proud of the gas there!
Frank Lee 12-23-2010 08:02 PM
Ethanol free is good for older stuff- prior to '88?- that has carbs and non-ethanol resistant rubber parts. Since lots of boats are old, it's a legit selling point for them.
For cars, not so much. Not so much at all.
nemo 12-23-2010 08:24 PM
The amount of ethanol should be required to be posted, if any.
comptiger5000 12-23-2010 08:36 PM
In the marine world, ethanol rated fuel hoses and such started in 93. We had to re-do the fuel lines on our 86 Chris Craft due to issues, and one carb developed a seal issue after about 6 or 7 seasons of ethanol. Other than that, it hasn't been an issue. Fortunately, the fuel tanks are aluminum, not fiberglass.
I've never gotten to run E0 in the Jeep to compare mpg, but it runs fine on E10, and doesn't seem to care one bit. As long as it's got enough octane for it not to ping, it's happy.
