Geo Metro Fuel Filler Neck Refab
The fuel filler neck on the geo goes down the back of the fender, and is covered by a piece of plastic. Once dirt and water get up here, it's rust heaven.
My filler neck rusted 2 holes through it. This is a Dealer only item at $366!!!!!!!! Me and the guy at the parts counter just laughed. So on to Napa for some Fuel Filler line, and on to Home Depot for some Galvenized pipe fittings. http://ecomodder.com/forum/member-no...neck-holes.jpg I needed to keep the vent, luckily, that was the only part still in good shape, so I cut about an inch below the vent, giving me room to attach a new line. Fuel filler hose is not flexible. Radiator hose can not be used for fuel, it will eat it. http://ecomodder.com/forum/member-no...ck-salvage.jpg It's a little over an inch from the tire, just far enough not to rub. When I have a little more time I can make some adjustments and get it tucked in a bit farther. http://ecomodder.com/forum/member-no...2-new-neck.jpg Total price, about $20 |
Had to take it out to made an adjustment to get it further away from the tire, so took a picture:
http://ecomodder.com/forum/member-no...-finished2.jpg |
It's all about functionality...nothing else matters.
That saved you over $300.00 and looks like it would be very safe. Better than dripping gas all over the place!
Excellent work. I don't mean to be a conspiracy nut but it really is weird that there seems to be a few random "dealer only" parts that fail easily. It's almost as if they already knew ahead of time those parts would fail... :confused:
PVC version of your mod? Hmmm...
Just had a thought...would PVC be an acceptable material, or does gas effect it? It seems a better solution if it can withstand constant contact with fuel...
Hacksaw. |
However, if I did have a buddy that bent exhaust, I'd have cat-free systems on both Metros right now...lol Mimicking the OEM part would be ideal, but solving a problem quickly, and on the cheap, often prevails! |
