Geo Running Sluggish....
I may take the cake with the number of Geos I currently own, but it's one in particular I am having trouble with: My current daily is a 92 convertible, auto. You guys should know all the specs hands down: 3-cyl, G10, etc., etc.
Lately, my little baby has been running a little sluggish. :turtle: The symptoms started very suddenly: drastically reduced performance, struggling to acquire speed from red lights, complete inability to reach highway speeds, let alone hitting 35 in a 35 mph zone. :( From previous Geos, I knew that the EGR valve was very prone to getting clogged. I removed the little bugger, scraped out as much of the carbon as I could, replaced the gasket and the whole nine yards. Took it for a spin the same day out on the highway, and no problems reaching 65 and 70. That was yesterday. Wasn't there a song by that title? Anyways, similar story, different day (SSDD). While not as bad as previous symptoms, the car still seems to struggle to reach speeds. Before, I was quite impressed at how fast I could jackrabbit start out and leave the guy behind me in the dust. I know, I know, jackrabbit starts are detrimental to ones' fuel economy. What else can I check before I **gasp** take it to a "mechanic"??? Cat converter? Sensors? I am talking about stuff an average Joe can do with average tools. I have absolutely no way to check compression, and wouldn't know how to even if I did have the equipment. None of the dash indicators are lit- not even the dreaded check-engine light. Yet, something tells me she just ain't what she used to be, and it's got me annoyed. Some more things I've noticed: The car seems to run perfect when I first start out for the day. I use the little beast to deliver pizzas PT, and I don't notice anything really wrong until maybe 1/2 way through a 5-hour shift. The car seems to take longer to reach "cruising" in-town speeds, seems to gradually take longer to accelerate, and my mpg seems to be rock bottom, although haven't yet computed it for a shift yet. Seems I may drive maybe 40 - 50 miles per shift, and I am using nearly 1/2 a tank to do so, so what's that equal out to? Something like 10 - 20 mpg, when I should be getting closer to 30 in town. Any ideas? Something's ailing her... just WHAT??? :confused: Haven't yet checked the Cat converter. Everyone knows what the cat seller is gonna say: "Yup, she's bad. Gotta be replaced. When you do wanna set up an appt?" No matter what it is you take your car in for to be checked, the mechanic is pretty much gonna say it's bad and has to be replaced. :( Signed, Sluggish in Cincinnati |
Catalytic converter can have a terrible effect on the performance and fuel economy... I would check that.
I would also check the basics.... air filter, fuel filter, plugs, wires, cap/rotor (assuming it has a distributor), make sure your brakes aren't hanging (do the wheels spin freely?), does the throttle body test to see if the butterfly is opening all the way. It could be a sensor of some sort. Hope this helps! |
Does the fuel level in the tank make any difference?
Thanks for the replies, redline & fumes. I pretty much checked everything I knew how to check. Nothing is lit on the dash, so I am guessing all the sensors are reading OK. Just had the brakes re-done all the way around the car. Fuel tank level doesn't seem to make any difference whatsoever that I can discern, although I hadn't thought of that. I generally keep the little beast at "full" anyways, but I'll try to let it run down to (gasp) almost nothing to see what effect that may have.
Never checked a fuel filter, so I'll look to see how to do that and give that a spin. Thanks! |
There are several listservs specific to keeping Metros healthy. Overall, they are far easier to work on than most cars, but the fuel filter is in the tank.
The fuel filter is in the tank? Or the fuel pump?
Both. The filter protects the pump. You might want to buy a manual for the car. I hear complaints about anything but the factory service manual, but Hayne's is at least helpful.
Just a suggestion, don't drive the auto 70mph.
Actually, though, the city driving is more than likely harder on the car than regular highway driving is. |
I'd be suspicious of a vacuum leak. I had one on my car and it had symptoms like you describe: ran poorly when warm, reduced power, and ate fuel at about a rate of 20 mpg (US).
It did not set off the check engine light. |
I diagnosed mine with a ScanGauge (MAP - Manifold Absolute Pressure) reading which showed it way out of normal range. ScanGauge is not an option on your '92, unfortunately.
Google "how to find engine vacuum leak" for other detection methods (that's what I'd do). Has your exhaust become smellier or more noticeable (cloudy)? Mine did, because the vac leak caused a rich condition. |
What's Google? Haha- Just Kidding. Will check.
Nothing coming out of the exhaust any smellier than normal. |
I suspect a clogged cat, clogged fuel filter, poor spark, or low compression.
I think some of the later Metros had just an in-tank filter instead of the screen bag, but your '92 has an external filter. |
i'd check the vaccum lines, filters (fuel air Etc), also a fuel regulator may have somethin to do with it
