Old 01-11-2017, 12:20 AM   #1 (permalink)
Ecomodding Crazy
zach mobile - '96 Chevrolet s10 ls
90 day: 26.95 mpg (US)
Glider - '18 honda civic SI
90 day: 34.7 mpg (US)
Foxy - '06 Honda Insight
90 day: 59.69 mpg (US)
Sky - '03 honda s2000
90 day: 28.62 mpg (US)
roots blower instead of butterfly valve
Let the intake vacuum do work on the roots blower.
My brother's car is 2L, 60mph is 2600 rpm.
That would be about 73 cfm at wide open throttle, actual engine intake is 17 inHg cruising.
my math is a bit fuzzy but it looks like maybe 2 hp theoretical is available.
Old 01-11-2017, 01:29 AM   #2 (permalink)
Yeah 4cyl gasoline engine cars typically lose about 2hp to isobaric losses.
Easiest way to fix that is get a diesel engine.
Old 01-11-2017, 01:46 AM   #3 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Yes, you will probably gain efficiency with a roots blower anyway. On a 2L engine I recommend an SC12 from Toyota, it's clutched like an A/C compressor, so you can even toggle it on and off at will.
Old 01-11-2017, 05:12 AM   #4 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
This has been invented many times.
My version first heated the air by extracting heat from the exhaust system, used a turbine to produce power, and finally cooled the air again before it went into the engine.
Old 01-11-2017, 05:20 AM   #5 (permalink)
Will someone please explain... any single part of this? Thanks!
Old 01-11-2017, 09:40 AM   #6 (permalink)
...beats walking...
It takes POWER to suck air through/past a partially open orifice (throttle).
