Global Cooling
Last week, PBS NOVA aired, 'DINOSAUR APOCALYPSE', which had to do with the mass extinction event, 66-million years ago, which took out 75% of all species on Earth, including all, non-avian dinosaurs.
Something which stood out had to do with 'Impact-Winter,' created by 3-trillion tonnes of sulfur-based rock, from the Yucatan Peninsula being vaporized, and ejected into space. Earth's gravity pulled the vaporized rock back into the atmosphere, where it gave its heat up, allowing the vapor to cool into glass spheroids, which rained down, while turning the air into a hot-air broiler, incinerating most terrestrial and oceanic life forms. Earth was dark for about a decade, all food systems collapsed. -------------------------------------------------------------------------------------- The interesting part was that, the sulfate aerosols created by the asteroid impact, remained in the stratosphere long enough to cool the whole planet by 48-degrees-F. This phenomena was first discussed by Benjamin Franklin, who coined the term ,'parasol effect', which is used in today's general circulation climate models. -------------------------------------------------------------------------------------- Today's 'cooling' is associated with coal-fired power plant emissions, which are keeping the troposphere about 1-C cooler than it would be without the aerosols. In effect, the Earth has already warmed 2.1-C, we just won't 'feel' it, until all these plants are taken offline, and the aerosols have a couple months to precipitate out. ------------------------------------------------------------------------------------ If you haven't seen the show, it's worth a look. The paleontologists have reasonably demonstrated that dinosaurs were present right at the time the 'Mount Everest'- sized asteroid came in at 45,000-mph. None, except the 'chickens' existed afterwards. |
A more recent example was the week or more in 2011. DDG's top result
https://weathermodificationhistory.com › september-11-2001-airline-groundings-contrails-affect-daily-temperature-rangeIs the 12,000-year cycle more likely to be asteroids or vulcanism? |
Proving the point that even asteroids are a more concerning existential threat than the outdoor thermostat going up a couple degrees?
Seems to me Gretta should be pulling her hair out that we've not sufficiently guarded ourselves against that inevitable event. "How dare us". |
12,000-year cycle
2) The asteroids large enough to be detected are continuously monitored around the clock. 3) 'Vulcanism' or 'Volcanism?' I don't know anything about 'vulcanism'. 4) Volcanism is not periodic in nature. There are no 'cycles' associated with it that I've experienced in the literature. It is associated with tidal forces, plate tectonics, lithospheric isostatic rebound as ice sheets melt, and seismic activity. 5) The Milankovich 'wobble' has a periodicity of 23,000-years. 6) The 'tilt' cycle is 41,000-years. 7) The 'ellipticity' cycle is 96,000-years. 8) The solar sunspot cycle is eleven years, with a delta-irradiance of 0.50%. |
Global warming's a sure thing. It's accelerating, non-linearly, as I type. It will ultimately be the 6th mass extinction. It's what the people who control information want, and they're going to get it. A great success story! |
DDG says: Quote:
what would yellowstones eruption do to the planet? at least we can stop an astroid. cant stop yellowstone...
Dansgaard..................
Willi Dansgaard of Denmark is the namesake for the 'Dansgaard' half of the adjective. 'Heinrich' refers to 'so-called' Heinrich ice-rafting and iceberg discharge events ( boulders and everything to make glacier moraines ), transported for vast distances; associated with Ice Age terminations and Younger Dryas, which introduced freshwater pulses to the oceans surface water, affecting cessation of deepwater convection and circulation because of thermohaline/ density issues. At 12,000-years ago there was a 'Allerod warming' where a vigorous deep convection returned. |
Yellowstone super-volcano
Same for all living around the caldera at Carson City, Nevada. |
When the next vei 7 pops we won't have the luxury of worrying about the man made global warming fantasy.
air quality and temp
2) everyone within a thousand miles would be dead. 3) Skies could be darkened for two years, 4) Mount Tambora's 1815 eruption cooled the whole planet 2-F. 5) all depends on magnitude of eruption. |
But, you asked: Yellowstone Supervolcano Simulation edit: Some general volcanic disater porn -- What If Yellowstone Blows Up In 2022? It turns out volcanoes are good for you. Except the Long Valley Caldera? :eek: Quote:
'we'
Presently, NASA's plan is send a spacecraft out to any Earth-intercept asteroid and give it enough of a nudged force vector, to deflect its trajectory away from us.
NASA's already successfully landed spacecraft on asteroids. A small, impulse rocket motor, operating over a long-enough duration, could do the job. Not 'sexy', but it'd get it done. |
I know a recent European probe to an asteroid didn't go so well.
park it
That might cost the entire global GNP. You'd want to know that it was worth it, ahead of time.
news.slashdot.org/story/22/05/23/1626245/pakistan-hits-120f-as-climate-trends-drive-spring-heatwave
This is insightful to Slashdot's current state: Answer (Score:5, Interesting) by Okian Warrior ( 537106 ) Quote:
I plan to maximize flourishing during changing climate, because I'm maximally equipped to respond to events in my life, and everything else I have minimal control over.
Authoritarians are out of control and need outside influence to regulate their environment (outdoor thermostat for example) and Liberals leverage control over the things they can, leaving as little to chance as possible. |
Then there's all that too.
I like how global warming belivers can think that protons from a solar flare can hit the poles at 90%+ the speed of light and simply nothing happens. |
There're cycles within cycles. More than we knew:
www.esa.int/Applications/Observing_the_Earth/FutureEO/Swarm/Swarm_unveils_magnetic_waves_deep_down Quote:
My hypothesis is that to understand completely the most simple thing in the universe would require complete understanding of all things in the universe.
Everything is the result of prior first causes. |
To get the right answers you need to start with the right questions.
I find grounding in Arthur M. Young's Reflexive Universe, and Fuller's Synergetics. Young is summarized here: arthuryoung.com/books/the-reflexive-universe/ https://arthuryoung.com/wp-content/u...c-1024x408.jpg Light gives up degrees of freedom, until you get rocks, then a miracle happens and degrees of freedom are regained. Each level has seven sublevels, we're at a sub-seven level. Also a teaser for his next book on Formal Expression for Control: Position and its Three Derivatives |
The Faber college motto was 'Knowledge is good."
Buddy James: Geometry of the Electric Universe | Thunderbolts If a rabbit hole goes over your head, that can't be a good thing, right? |
what's new
2) 'Waves' is too ambiguous. The Sun generates the entire electromagnetic spectrum, which can be represented either as photons or waves. Only a very small percentage of the overall energy can penetrate Earth's atmosphere. So we need specificity. 3) Any travel time is limited to the speed of light, so anything 'immediate' is automatically ruled out as a violation of physics. Nothing on Earth can be experienced any sooner than eight minutes from the time something occurs on the Sun. 4) Is what you're talking about limited to the Equator? And you understand that the position of the equator, with respect to the Sun, changes every day? |
protons.........happens
All who routinely observe the sky are acquainted with aurorae, a classic phenomena associated with plasma bombardment of the magnetosphere. One example of something happening, which nullifies your argument. |
European Space Agency
I'll have to get back to you on this one. |
to the Earth's surface
Meditate on this: https://nasaviz.gsfc.nasa.gov/vis/a0..._Processes.jpg https://nasaviz.gsfc.nasa.gov/4641 NASA have moved beyond your Crystal Spheres weltanschauung. I highly recommend the video at #25. It starts with Plato. And gets you to co-axial filaments without any cable. |
comment... heliosphere... meditate
2) The question about the heliosphere is also quite straightforward. Are you ever going to give me a simple answer? 3) Of all the 'spheres' you mention, the troposphere has been omitted. It's the only 'sphere' which is germane to the topic of global cooling. Why do you intentionally deflect the conversation away from the only thing associated with the subject. 4) And add to it, as if we haven't moved away from the subject far enough already. 5) If you want to discuss failed philosophers you could start your own dedicated thread. |
_____________ Quote:
I kept adding to the list when I found out what ITM stood for. I didn't realize the troposphere is the only one that counts. ____________ Quote:
The only thing null is man made global warming. |
satellite trio
2) I number my paragraphs because you requested that I do it many months ago. So we could segregate thoughts, item by item. 3) I don't know what ITM stands for. 4) Birkeland currents aren't on the table for discussion at this thread. 5) Alfven waves I brought up a year or so ago when you couldn't remember them. Why don't you read my replies when I give them. Are you just into total disrespect? A pen, paper, ring binder, and top-loading sheet protectors would allow you to assemble work books assigned to specific topics. That's what I do. 6) If you want to demonstrate space weather prowess, start a dedicated thread. I promise that I won't disturb you there. I don't do space weather anymore. If you've read my comments over the past year, you know why. Apology, I forgot about 'Cosmic Catastrophe' from 2019. Glad the world ended back then. I was afraid it would happen. My revenant life is much better. |
seconds or minutes
B) Earth is an average 92,960,000-miles from the Sun. C) 92,960,000 / 186,000 = 499.784-seconds transit time between Sun and Earth. D) 499.7840seconds / 60-seconds/minute = 8.329-minutes transit time for light, between Sun and Earth E) I quit bringing my space weather workbook with me, so I'm at a loss to tell what the velocity of the solar wind is. It is 'ORDERS OF MAGNITUDE' slower than the speed of light. F) I'm commenting for the benefit of our guests, as you're obviously struggling to keep your quanta in order. Someone's got to do it. G) I won't dignify your last comment with a response. |
term
Please don't say anything about space weather. If you want to contribute, limit your remarks to global cooling. This may be my thread, however, I have no recollection of ever using 'ITM' in any posting. So you don't read what I post. I've explained why I left 'Cosmic Catastrophe.' I think I'll just abandon this thread. There's no future in it. |
It's all cool. :)
ITM defined at Permalink #32. |
