GM's 200 mile electric car
GM working on 200-mile electric car, exec says: Associated Press Business News - MSN Money
With current battery prices it should be possible, $18,000 in batteries should be able to power a car for 200 miles if they can keep the watt hours per mile down to 250 watt hours per mile and that is possible with batteries that I can buy at bulk prices right now.
That would be around 1,000 pounds of batteries of course. As it is the 10 cheapest cars in the USA are $12,800 to $15,300, pull the cost of the gasoline parts and a glider might be as cheap as $10,000, leaving around $2,000 for the motor, controller and everything else. So it would be tight to make a $30,000 car with a 200 mile range, but possible. |
The GM EV1 was able to go ~55MPH at ~150-160Wh/mile, so that would greatly reduce the battery pack requirement.
The Nissan Leaf uses 233watt hours per mile at 55mph, but the average American doesn't drive like that! but a 24kwh battery from a Leaf would get it close to that 200 mile range.
Question is, what is the EPA rated range, at 70mph, going to be? |
I could drive to my parents' house!
Also, I could use my electric car as an excuse for not driving further! :D |
Put 100,000 miles a year on your car because it's so cheap! other then the congestion and road repair costs. |
Would doubling our roads handle that? Obviously, we need to perfect micro homes and self-driving cars, then we can pave the world and never stop moving from one stretch of asphalt to another! |
I am sure it will turn out like the 238MPG volt and it will be built after the next time our government bails them out.
Guys, you can use the red triangle ! icon in the lower left corner to report the post. ;)
But a true scammer at the very least. |
Yeah... deleted. But FYI, don't quote them! The only reason they post here is to hi-jack our Google ranking to promote their spammy links, so quoting them helps them.
ON TOPIC. Is it worth while to have a fully electric car with a bigger battery than just a small tank, and the engine (diesel maybe, .5L?) just charge the battery when it gets low? |
Not going to, though, that would be bad! Quote:
There is an on-topic? That is allowed?! :P |
Top Gear made one. Seriously, I know it was entertainment and a big joke, but it worked. It's not the solution but it's a cheap alternative to hybrids and electric. |
I have already seen some portable gensets fitted with stationary single-cylinder Diesel engines with a built-in fuel tank, which could be easily contained under the hood of a Focus or a Cruze. The batteries could be mounted in the place of the OEM fuel tank.
I have already considered some different setups for the fuel tank, to save some space, such as a custom one to be mounted behind the dash, altough that would probably be illegal... |
I honestly have no idea why more than just a handful of people would want, or require, their electric vehicle to go 200+ miles on a charge. 265 miles on a Tesla is absurd, and a waste of money.
Most families have 2+ cars, one of which should be a gasser. If the need arises to travel more than 100 miles, they should take the gasoline powered car. For those that have only an electric car in the stable, they should temporarily swap for their friend's gasoline car for the longer trip... and these are just 2 of the many other solutions to the range anxiety people have concerning electric cars. I'd like to see a Leaf equivalent car sell for ~$20,000 and be available in the used car market (private party) a few years later for half that price. One of my cars would then be electric. As it is, there is no cheap commercial option out there for me, so I'm likely to purchase a used Prius. The generator idea has been discussed at length in this thread, starting at about post #154. To sum it up, if you're going to burn fossil fuels to propel a vehicle, it's more efficient to directly use the mechanical energy in a mechanical way, (IE pusher trailer). Extending the range of an electric vehicle using gas defeats the purpose of an electric vehicle. |
Not all power comes from rainbows, sunshine, and gentle breezes- it's still a fossil fuel somewhere. But that would offer an alternative. If some one from horseville was on the fence about an alternate fuel vehicle, would they be more likely to risk an electric vehicle, or use one with a back up? Using gas is the opposite of defeating the purpose. It's expanding the purpose in a cost effective manner. Not wasting weight, money, and resources on batteries that will go unused. 40% of the batteries and a little generator could do wonders on a 200 mile commute, 20 mile commute, or 3,000 mile cross country trip. |
If you read through the other thread I linked to, you will see that I started off on the side of generators for all EV owners. Eventually I crunched the numbers and came to the conclusion that it only makes sense if someone already has a generator, or has an alternative use for a car generator, such as emergency power for the home. |
