EcoModder.com
-   Success Stories (https://ecomodder.com/forum/success-stories.html)
-   -   Goal #1 attained, perilously close to #2 and #3 in sight! (https://ecomodder.com/forum/showthread.php/goal-1-attained-perilously-close-2-3-sight-26179.html)
Flakbadger 06-18-2013 11:35 PM
Yesterday I broke 500 miles on a single tank! When I bought the car I was averaging 350-400. Once I got my Ultragauge I began to break 400/tank consistently, and set a goal to break 500.
Well, yesterday I did it, and could have driven another 20 or so before risking running out of fuel. SUPER EXCITED!
Goal #2 is to break 40% over EPA. I remember how excited I was when I broke 20% over EPA. That seems like ages ago.
Goal #3 is a 50 MPG tank. That's going to take some effort, as even getting to the ~47 was more than moderately difficult.
I have found that using the MPG/trip feature on the UG nets me tremendous results, I reset it every time when I park. I also highly recommend the trip log if you don't already use it.
Anyway I'm done bragging, thanks for listening!
~Matt
Xist 06-19-2013 01:27 AM
That is definitely good for an 11.1-gallon tank. I can go 450 on my 15.9-gallon tank, but I am not sure what it would take for a 30 MPG tank.
AndrzejM 06-19-2013 02:53 AM
Matt, that's great, congrats! It's just great a great feeling to brake the record, or to achieve goal. But you have to remember that it'll be a constant struggle. First I was wishing to have an average below 4l/100km (58.8 mpg US), now I'm thinking of breaking 3.5l/100km barier (67.2 mpg US), first for a longer trip, then for a whole tank.
So good luck man! Good job, and thanks for sharing your excitement. :thumbup:
Jyden 06-19-2013 09:52 AM
~Matt
My goal is to beat Matt - and do it in a 9 y.o. car, previous model. So I'm breathing down his neck. Just wait and see. My 90 days numres a low due to late spring here. My 3 tank avarage is much better :)
Well done Matt - nice little fuelsavers we've got
terror_storm 06-19-2013 12:57 PM
Perhaps my UG version is different than yours. Mine has short trip ("srt") values that reset when the ignition is switched off for >5 seconds, no manual resetting required.
SentraSE-R 06-19-2013 01:39 PM
Good job, Matt, but you need to set the bar much higher. I drive a Scion xB with higher cD, much larger cDA, and shorter gearing (OEM gearing forces my engine to run at 3100 rpm @ 60 mph). We share the same engine, Toyota's 1NZ-FE. Admittedly, I have a slightly larger 11.9 gallon gas tank v. the Yaris' 11.1 gal. tank, but I'd choose to drive your car rather than mine to achieve your goals.
Here's how high the bar is for you Tercel/Echo/Yaris/xA/xB people. I have 21 of 121 tanks >500 miles, including 3 tanks >600 miles. Two of those tanks were over 1000 km (621.37 miles). I'm not trying for maximum distance tanks, either, as 15 of my 121 tanks are <200 mile tanks. I'm quite willing to top off my tank in Nevada or Arizona or Georgia with cheap gas before crossing the state line to higher prices. And I do a lot of cross-country driving where I don't want to be down to within a gallon of the low fuel light in unfamiliar territory.
I'm running 76% over EPA, for more than 45,000 miles.
I have 49 of 121 tanks >50 mpg, including 4 tanks >60 mpg.
Good luck ;) I'm not trying to intimidate you. Take the higher bars as challenge and inspiration. If I can do it in my boxy xB, you guys in your streamlined Yarises should mop the floor with my rolling hay bale.
http://i1179.photobucket.com/albums/...gxB/horses.jpg
Flakbadger 06-20-2013 05:10 AM
Xist: I think you're fighting a lot of things in an older Subaru; bad aero, full-time 4WD and engines that aren't necessarily built for MPG's. But, then, the car will probably go for 300k miles, so there is that...
AndrzejM: Your goals are impressive, but so are your results. I look forward to seeing a thread about you breaking 3.5/100km
:D
Jyden: I am a little envious of your 1.0 liter engine. We don't have that option in the U.S., only the 1.5. Good luck on your goals, this winter really destroyed me too (and winter here is pretty minor comparatively), but once it's 90 days behind you things will look up!
And I love the Yaris too.
Terror storm: I didn't know that was a thing! Thank you, I'll look into that tomorrow!
SentraSE-R
: You're not intimidating me, my eco-driving goals are set low enough to be obtainable just as benchmarks for progress. One of my old goals was to be 20% over EPA, which as you can see I smashed. Once I achieve a goal, I set a new one. It's a good way to keep forward progress.
I am impressed you get the numbers you do with your vehicle, being that it is (as you call it) a rolling hay bale.
Do you do a lot of engine-off driving? Because I do next-to none (with a few exceptions). There are a couple long hills that I will EOC, and a few particularly long stoplights, but otherwise I'm an engine-on driver.
My point is that if you do EOC and I don't, I'm probably not going to beat you any time soon, because my only advantage becomes the aero one (and the gearing, there is that).
Anyway thanks everyone, happy Ecomodding.
~Matt
PressEnter[] 06-20-2013 07:49 AM
Congrats! I'm sure you'll get 50 mpg and then some in time.
I am happy with my 14.5 gallon fuel tank, though. One of my goals is an 800 mile tank :p
SentraSE-R 06-20-2013 10:11 AM
Matt,
Yes, I EOC all the time in local short trips, but almost never on long highway drives. It's the difference between 60 mpg and 40 mpg in my xB. If you don't EOC, you're taking a similar penalty. OTOH, your Yaris is much more capable. Another hypermiler & I drove the same 10 mile loop, & he matched my 60+ mpg P&G with his Echo. But he drove it without P&G or EOC. He kept his in 5th gear. When I drive mine the same way, I get about 10 mpg less = low-50s.
You & I must have the older UG. The current UG EM has the automatic trip reset feature. We can upgrade our software to EM for a nominal fee.
Flakbadger 06-20-2013 11:08 AM
Originally Posted by PressEnter[] (Post 377109)
Congrats! I'm sure you'll get 50 mpg in time and then some in time.
800 is pretty impressive; I wish my car had a bigger tank. Sure it's cool that it's <$40 to fill most times, but it would be nice to drive another hundred miles or so. Anyway thanks!
Originally Posted by SentraSE-R (Post 377133)
Matt,
I do love the efficiency of this car, I get awesome results without really "trying," to be honest once I bought my Ultragauge I felt like I was cheating or something. Once I finally figured out to program it to recognize DFCO my FE jumped by leaps and bounds.
I need to read up on P&G some more, the concept makes sense but it seems overly laborious to me.
As for upgrading, not worth it to me until this one breaks, which with the way I treat my stuff is going to be a very long time :)
