God, I love my MpGuino!!
I was trying to figure out why my Guino keeps resetting tonight and decided I would practice P&G a little more. The coolest part about the guino is the big current display, can instantly tell if your mileage is going up or down. No more waiting to fill up and see.
I shocked myself tonight with this one. http://i219.photobucket.com/albums/c...MpGuino001.jpg http://i219.photobucket.com/albums/c...MpGuino002.jpg 89.2 over a distance of 9.37miles all in town!! :turtle: I am totally freaking out at this point, the MpGuino and P&G rock. :thumbup: :D |
You'll skyrocket your MPG :D Quote:
TIA, Denis. |
All my connections were made at the ecu under dash, except power ground which are to ignition switch battery feed wire, and ground is to chassis.
Yeah will definitely take up mileage, the best I pulled before in town, without guino was 57mpg. |
Nice job! That's a very impressive trip right there
Good job, hope you get the rest of it figured out. Hope the new resistors make a difference, but Im really not sure what to use, Id have probably tried the same as you did.
I feel like I cant live without mine either. I prefer the first display, so I can keep an eye on both the instant mpg, and use that to keep the current mpg up. Occassionally Ill toggle to the tank mpg just to see, then toggle back. I also usually use the first display as my speedometer, since it is very stable and more accurate than the factory needle. Im still running version .70 since it works 100% flawlessly for me. Got my best trip and tank last night. 38.6 tank average, and my trip back from downstate last night to the local gas station was at least 39.84 mpg over 142 miles. Guino read 5% high on fuel use, so it was probably more like 41.8 mpg. Im getting variations of about right on to about 8% high, most likely based on fillup differences. +/- 4% is pretty good. I should probably reset my microseconds/gallon to about 4 or 5% higher which seems like the average, but I kinda like knowing that Im getting at least what it says I am, or a tad better. I should at least go average my variations so far and change it in the wiki page. |
If you build me one for my 95 jeep cherokee 4.0 6cyl ill buy it, it does have a digital or electronic vss, and i know where all wires are for each injector which are 228cc 43.5psi max, right now psi is 38 or 39 so they flow 220cc approx. at 22psi and are all 16ohms
8000 pulses, no cruise control build me one and ill buy it, her is my email justinta@verizon.net |
what do you mean by "practice P & G"?
