EcoModder.com
-   The Unicorn Corral (https://ecomodder.com/forum/unicorn-corral.html)
-   -   Good for a laugh or a cry (Gravity Plane) (https://ecomodder.com/forum/showthread.php/good-laugh-cry-gravity-plane-29266.html)
ConnClark 06-18-2014 04:20 PM
This is good for a laugh or a cry when you realize someone actually invested in it (or accepted money to do research on it).
The Gravity Plane
https://www.youtube.com/watch?v=tPbu5UeW4uk
inanitydefined 06-18-2014 04:43 PM
Biggest problem I see... What use is it? The design has near nil passenger or cargo space, and using bouancy to generate lift would mean cargo mass would have to be tiny in proportion. It *may* work as a toy or a single seater but has zero commercial use
chumly 06-18-2014 06:06 PM
[QUOTE=inanitydefined;430 It *may* work as a toy or a single seater but has zero commercial use[/QUOTE]
"They" said the same thing about the airplane way back when. It does seem pretty far fetched but you never know, someone might be able to do something similar someday. We did go to the moon since then.:thumbup: Chumly
P-hack 06-18-2014 06:48 PM
it is interesting, haven't done the math, but seems possible, am i missing something obvious (aside from wind drift)?
P-hack 06-18-2014 07:29 PM
the basic question is how much energy does it take to compress the bouyancy fluid vs how much you can borrow on glide. if you arent in a hurry but still want distance made good, then maybe... using the compressed air for thrust before ascending is clever, i dont know if floating is fail safe if the compressed air leaks though. will need ground anchor if unattended
Cobb 06-18-2014 09:25 PM
Im sure newtons laws will hold true regardless of the mode or travel. It cant be created or destroyed and you can never get more out than you put in.
Now solar or nuclear powered is another story. Nothing like a nuclear scram jet. :thumbup:
sheepdog 44 06-18-2014 10:14 PM
I imagine is has a very impractical top speed. And the slow climb up and descent glide down makes you wonder what purpose it would have.
Superfuelgero 06-18-2014 10:31 PM
Drone. Much like historical use of lighter than air craft for 150 years.
P-hack 06-18-2014 10:54 PM
Yah probably, the energy to compress for descent is likely the same as the energy gained in climbing (minus many losses along the way). Wish I knew how to do that math.
My money is on solar impulse.
basjoos 06-19-2014 01:17 PM
Another variation on the scam of the perpetual motion machine. Interestingly there is something similar to this currently operating in the world's oceans (google "underwater glider"), but underwater gliders don't make the claim of using no fuel. Underwater gliders use battery power to make the buoyancy changes to travel very efficiently for months through the ocean. Look up the Navy's Liberdade class underwater gliders.
