Old 04-21-2009, 03:26 PM   #1 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
linoleum against radiator potential fire hazard?
i've alway been a little disapointed with the effect a grillblock has on my car, in fact i think it seems to lower my fe... today i took apart the airbox and air intake system that seemed to get it's air from somewhere in the front bumper... turns out most air for the intake is coming from the left side of the topgrill... so today i inserted a sheet of linoleum behind the grill so that it directs most air towards the pickup.
now to get the the point. this sheet touches the radiator... is this a potential fire hazard?
Old 04-21-2009, 04:03 PM   #2 (permalink)
I wouldn't ever block with something right on or next to the rad. Even in severe cold when I button the front up, I leave room for air to circulate through the rad. However if it's only touching on a small portion of the rad it's probably OK. 200 degrees probably wouldn't cause lino to burst into flames... but I'd look it over periodically for signs of heat damage anyway.
Old 04-21-2009, 05:26 PM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
it will not get hot enough to burn, but it might soften and turn in to a mess that is hard to remove.
Old 04-22-2009, 11:18 AM   #4 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
Linoleum is made up of mostly PVC and it's Melting point is 100–260 °C so you should be set. Just keep an eye on it though.
Old 04-22-2009, 12:36 PM   #5 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
I agree, I would leave some room for circulation. My cars run cool, but there is one thing that heats it right up to a danger point, and that is ice and snow packed into the lower part of the radiator.
Winter daily driver, parked most days right now
Summer daily driver
linoleum as aero-mod meterial!!! lunarhighway Aerodynamics 0 02-26-2009 06:37 AM
HELP! S10 hazard button broken! bennelson Off-Topic Tech 17 05-08-2008 11:05 AM
