EcoModder.com
-   Success Stories (https://ecomodder.com/forum/success-stories.html)
-   -   Got 2.25 L/100 km 104.36 mpg (US) at 80 km/h avg speed (https://ecomodder.com/forum/showthread.php/got-2-25-l-100-km-104-36-a-22054.html)
Vekke 05-27-2012 02:52 PM
Did some quick test run to see the cars current performance with latest mods on.
Results 2.25 l/100km at about 80 km/h avg speed. Did no drafting on this short tank. Now the car starts to have all the planned major aeromods done, only the fron wheel skirts are missing but current 80 mm groung clearance that will be little bit challenge to make them but will build them anyway.
Anyway car start to get closer its target consumption which still is 2 liter at 100 km/h avg speed.
More pictures about the cars current state at facebook:
Tuneko Ltd | Facebook
NachtRitter 05-27-2012 09:40 PM
Very nice!! Getting very close!
ecomodded 05-27-2012 11:00 PM
2.25L at 80 kmh is Incredible, Good work !
I like the grill on your car, it looks like it is designed to shut and open, it that your work or is it just a immobile stock grill?
meelis11 05-28-2012 04:19 AM
Very impressive results! Of cource this is with using P&G ?
Vekke 05-28-2012 10:39 AM
Yes full push and glide driving but the uphills. push and glide with load. Push from 80 to 95 and glide back to 80.
Front grill block is self made as most of other parts. At the moment the adjusting is not build there yet but there is that option for later.
euromodder 05-28-2012 12:41 PM
Nice work. :thumbup:
But seeing what it takes to get it in this small car, makes me ever more suspicious about 2.8 L/100km @ 60mph claims in a Passat ...
Vekke 05-28-2012 02:46 PM
You do have to remember that my engine and also other parts of the car have 260000+kilometers in the odometer. I believe that specially the turbo is not in mint condition after those miles. Plans are to change it to newer version and get better efficiency at the same time.
The Passat avg speed was only 40 MPH or so. At that speed lupo would hit 117 MPG on stock condition.
meelis11 05-29-2012 01:48 AM
What are your Pulse and glide times in seconds?
I keep engine in neutral and idling while glide. Pulse is 3.5-4 seconds (80-100 kmh) and glide is around 12 seconds (100-80 kmh) in level ground (two persons in car). Onboard computer shows 3.9L/100 after 490km driving. Computer is optimistic about 0.5L, so real number is around 4.4L/100km
euromodder 05-29-2012 10:46 AM
62 kph or only 38.5mph apparently, rather than 60 mph ...
That throws a different light on it.
Their performance in Holland (The Netherlands) under real conditions was far less impressive :
25.5 KM/L 1,020 KM'S driven - on just 40 litres of fuel.
That's 3,92 L/100km.
I've had Snert the replacement Volvo down to 3.999 L/100km ... with only the tyre pressure being increased.
Flakbadger 05-29-2012 11:33 AM
Congratulations Vekke! That is an outstanding result! Your mods look really clean too. I hope you reach your goal soon!
Vekke 05-29-2012 11:46 AM
Pulse time average is around 4 seconds and glide time around 15-16 seconds. You do have to drive uphills in glide with load to get best results. That lowers your average speed little.
I have made a chart where you can estimate your fuel consumption based on P%G ratio on a 1.2 TDI:
https://www.facebook.com/photo.php?f...type=3&theater
So with 4 seconds pulse and 15 second glide gives:0,266 P&G ratio which means about 2.2 liter fuel consumption.
You can make your own chart by making some assumptations on the engine power and BSFC map...
meelis11 05-30-2012 03:59 AM
You estimate there different things, but if you make car lighter, probably glide will be shorter also? I agree that lighter car needs shorter time to accellerate, but probably it also means that there is less inertia and glide is shorter too. Lets expect that aero and motor power are same. Or I am missing something?
Vekke 05-30-2012 11:14 AM
Only things that effect that chart is BSFC map. On TDI engines the average is around same
200g/kWh
Fuel density
0.85 kg/l
Engine power average estimation
40 kW
200*40 8000 g/h
8/0,85 9,41 l/h 0,002613889 l/s
on idle your fuel consumption is 0.5 l/h =0,000138 l/s
Then just calculate how many percentages you are on flat out near 2000 RPM and how much you are gliding.
Because your 1.9 TDI has 81 Kw vs 40 Kw it consumes double the fuel at same P&G times...
Lighter vehicle is not a big factor in the big picture the Cd value means the most when you are gliding in neutral at 80-90 km/h speeds. Ofcourse the bigger car has more energy storeged in itself but that takes also more energy to accelerate it back in push.
Was I clear enough?
I can send the exel sheet in email if someone wants to use it as well just send me private message...
meelis11 05-30-2012 12:25 PM
My question in short is: is there a point to make car lighter for pulse and glide type driving? Lighter car means shorter pulse and shorter glide. You are saying that pulse goes shorter but glide is not getting shorter by same amount? So there is still point in weight savings in P&G driving or is it mostly for city driving?
euromodder 05-30-2012 12:47 PM
While P&G is already cheating a bit, you're always losing out energy-wise.
During the coasting, you can't win back all the energy you put in while pulsing.
By making the car lighter, you're reducing the amount of energy it takes to pulse it from X to Y , so you're reducing the energy loss by reducing the energy that got put into it in the first place ...
A lighter car will have less inertia, but all else being equal, it'll also have lower rolling resistance.
Vekke 05-30-2012 02:53 PM
Difference is basicly the same as losing 10% of cars weight. In highway that means 2-4% savings in city driving that means 6-8% depending on the source. So when doing pulse and glide that 10% weight saving is at least 6% so yes it helps. Might be even more than 8% because you are accelerating all the time...
BMW530d 05-31-2012 06:24 AM
Don't forget your more economical in general because less weight = less braking so less wear. If youu know what it costs in litres of petroleum to fabricate and transport brake pads, thats also energy you can now consume for transportation. If you factor in all these lil bits your probably the most economical driver on the road ;)
ausias 06-06-2012 08:26 AM
Congratulations.
But if you are doing P&G between 80 to 95 kph, your average speed is somewhere near 87.5 kph (it tends to maximum speed becuase average increases when higher acceleration you have and lower the deceleration will be). MAths say average of numbers higher than 80 are higher than 80.
YOur fuel consumption is better than you say because average speed needs to be higher than you say or you are wrong in your numbers.
My car/s fuel consumption at 80 kmh now is 3.89L/100km (using cruise control) 1.9 TDI BXE 105 cv @ 138 cv. http://en.wikipedia.org/wiki/Seat_leon
It seems very difficult to me my car going under 3.5 L/100 km at 80 kmh (sport tires, standard underbody, standard gearing will be changed in near future but i'm not going under 3.5 at that speed). Maybe using push and glide but i only glide downhill.
My goal with my car is 5.5 L/100km at 120 kmh cruise control (standard it was 6.76 L/100km). Current fuel consumption is: 122 km/h cruise control 6.06L/100km (22km highway loop) and 5.9 L/100km (240 km higway loop). I will change tires, underbody and gearing in the future. I was focused on cheap aeromods (wheelcaps, grille, spoiler) and ecu flash because i wanted more power to overtake. 2008 Seat Leon Ecomotive Gearbox it's hard to find (but I have to because my topspeed will increase 15 kmh or 10 mph! and fuel economy improve).
I did some P&G with my year 2000 (310.000 km odometer) 1.9 tdi 110CV AHF and I got 4.5 L/100km at 110 km/h (100 to 120 kph interval) saving 0.5 L/100km, tdi's 5 th gear minimum efficiency it's high enough to show little improvement. The same car with Cd aeromoded from 0.31 to 0.28 gave me a fuel consumption of 3.08 L/100km (82 kmh average, using foot control speed). http://en.wikipedia.org/wiki/%C5%A0koda_Octavia
I use P&G with my car while city driving becase of awful effficiency of 1st to 3th gears at cruise speed compared with engine's maximum. I'm getting with the Skoda Octavia 1.9 TDI 110 cv AHF in the city 6.0 L/100km if I drive it with P&G, and long gears etc. Taxi drivers have fuel consumptioms of 7.6 L/100km with same car.
Diesel Trains doesn't need P&G and they get maximum efficiency at steady speed with correct gearing.
Does not using P&G on a 300 km trip sound crazy to you?
euromodder 06-06-2012 10:25 AM
Try to have the rpm just above the number given for max torque.
For me, that's about 85kph indicated, and it works wonders in my car when on CC : 2.8L/100km indicated, which would be around 3.3 in real life.
That seems very high for a 1.9 TDi ...
Try 4th ;)
With a warm engine I've started to do 30kph / 20mph zones in 4th gear, in my car that's at idle rpm, and CC doesn't work down there !
As long as the road is flat or slightly downhill, it'll give good results.
But uphill - even climbing a speedbump - the FC goes way up !
California98Civic 06-26-2021 07:27 PM
One of the best Ecomodder cars ever built/narrated on this site in my opinion... Vekke scored a 72mpg US lifetime and a 117 mpg US 3-tank average. Kicked US butt. I added it to the 70+ MPG lists:
https://ecomodder.com/forum/showthre...tml#post601190
