greetings from a "homeless" full time RV'er
Hello there!
I'm driving one of those Toyota 22RE motorhomes full-time, and working on getting my gas mileage up. It varies wildly, but I've never seen better than 15 and I know it can do better. I've already purchased an MPGuino, and I enjoy "playing the game" with the AI and gas mileage gauge whenever I drive, say, a Prius, so I plan to eventually rebuild my dash using that and a Raspberry Pi to get all kinds of data and also make my driving more efficient + comfortable. Solar is also on the list. It might result in my truck looking like the Delorean from Back to the Future, we'll see. I'm not computer stupid but I am a little car-stupid, so I still need to figure out how to hook some of these things up. I don't really live anywhere, but I'm kinda near DC a lot, helping with stuff in Maryland and Delaware. If anyone wants to jump on this project or see it ever, drop me a note! |
1 Attachment(s)
very similar! mine is a coachmen offshoot with a much more pointy body. 20 feet long. also, if I had to guess, that's the V6 toyota front end on a mini-winnie, mine's (as dictated by 22RE) the lowly 4cyl 2.4.
Welcome to the site!
Didn't those little toyota's come (optionally) with a small diesel?
I figure I should mention that much like my comment about a trans swap above, an engine swap is not really in the cards, really any modifcation to the vehicle that is gonna cost me more than a few hundred dollars is just not in my budget. |
A truck is a truck.
A typical Class C of the late 1980s was 7-9/mpg. So your little box is already “there” as per its specification. Double that of competition that though larger didn’t offer much more except space. 1). New shock absorbers 2). Examine tie rod ends, front end, etc. 3). Adjust out any steering slop at dead-center 4). Exhaust back pressure check. 5). Brake drag 6). Alignment There’s more, but you’re strapped for now. Must mean California or PAC-Coast. Best is to leave for a better place. The Moho penalty is in acceleration. Not enough engine. It’s only “right” on the highway. And then at a steady-state 1980s 50-55/mph. Burns too much fuel any faster as it’s working too hard. The sweet spot isn’t anything but use. Planned use. Moving it as little as possible. And then when traffic is lightest. As the cost of ground rent is higher than fuel cost, learning to accept what this vehicle, is best. The focus should be on reliability. All new fluids, hoses, belts, filters, spark plugs & wires. New battery & starter cables. NEW VEHICLE GROUNDS. Exterior lamps to LED (priority). Tire selection should be consultation with dealers. Tread design will matter. If this vehicle is being used daily to commute and it’s seeing 15-mpg, you’re doing well. Find schematic and get vehicle electrical grounds REPLACED (or at least cleaned & re-secured). Add a few across doors and hood. |
Front end is in good shape, as is alignment and brakes. Haven't checked out the exhaust or the shocks, but I haven't experienced any problems with that. I see people getting 18-20 so I am not shooting for crazy numbers, just a little bit higher...
