Grill Block (First MOD!!!)
So I decided to do my first mod after I got a truck shipment at work and had some extra cardboard. It looks horrible and ridiculous, but it is only temporary, so I can see how my FE increases (hopefully!). Later, I will make a long term and probably open-able one.
On the top block, I left the bottom row open, mostly because that's what size the cardboard was, but since this is my first try, I also don't want to block it too much and get it too hot. I decided to block the top row instead of the bottom row, so a little more air hits the radiator, rather than hitting some other parts which are higher up behind the grill (i.e. the hood latch and some other stuff). On the bottom, I left the sides open for pretty much the exact same reasons. :) Full View: http://i1289.photobucket.com/albums/...ps3cb3bb75.jpg Don't mind the damage on the left... previous owner :cool: Upper Grill: http://i1289.photobucket.com/albums/...psa4762676.jpg Just the lower row is not blocked. Full block on top and middle row from side to side. Lower Grill: http://i1289.photobucket.com/albums/...ps1cbff397.jpg Laying on the ground looking up (blurry): http://i1289.photobucket.com/albums/...ps26bd5242.jpg Laying on the ground looking up (straight on): http://i1289.photobucket.com/albums/...ps777b654b.jpg The upper grill is further back then the bottom grill. Laying on the ground looking up & slightly forward: http://i1289.photobucket.com/albums/...psed8b3afa.jpg I scuffed up the cardboard, but it didn't go all the way through, so it won't be a problem. I'm not really sure why my car has Styrofoam in the bumper, but whatever :) I'll keep everyone updated with how it works on my FE. |
Its a start, and it should gain you something.
Yeah, something...... Typically blocking the radiator helps in heat, blocking the front of the grill helps in aero, yet allows enough room for a fan to draw air as needed if things get a little too warm.
https://sphotos-b.xx.fbcdn.net/hphot...59484208_n.jpg |
Keep an eye on your coolant temperature, especially as ambient temperature rises.
And in San Jose, I expect they can rise pretty high ;) |
Good start! :thumbup:
As for the styrofoam, that is quite common in modern cars. It will absorb energy and deflect. In low speed accidents it will prevent damage to hard bits and is cheap to replace. |
It is about 80-81 degrees today and with a mix of city and freeway driving, nothing seems to be a problem. We shall see in the near future though! Quote:
Interesting, I've never seen it before this car, but it makes sense. I guess for those fender benders, it will help ease the damage. Anything stronger than that and I assume it won't do much good. |
Just an Update:
Soooo... it was hot today in San Jose! When I left work, the car's ambient temperature gauge displayed 89. It stayed pretty steady at 89-90 the whole trip. At one stop it hit 96 :eek:, but then later went back down to 90 a couple miles away. In other words, it was HOT! I was a little nervous, but watched my temp. gauge like a hawk! The whole trip, it never went above half way up the gauge, which is standard even without the grill block, but no concrete numbers to know exactly what was happening. I don't know if the fan ever came on to keep the temp. down. Coming up to a stoplight, I heard a sound I've never heard before, but I was not able to pin it down to the fans to know for sure. I only heard it the one time. When I got to my 96* stop, I left the engine running, opened the hood and the fans were not on. Obviously that doesn't mean anything for my drive, but at least at that point they weren't on. :rolleyes:
One of my stops was to my post office to pick up my UltraGauge!!!!! :D:D:D I haven't been this excited in a long time, I don't know why, but I guess it's just an eco-modder thing! (YNYAEM if...) So tonight I can start to calibrate it and get the screens how I want it and tomorrow I can attach it and see what the temp. of the engine actually is, rather than relying on the stock temp. gauge. I'm still trying to decide a location where I want to put it, but I have a couple of ideas. I have had the grill block for about half a tank (~200 miles), so the UG will be useful to know if the block is working or not without having to drive for tanks and tanks and tanks. The three things I noticed/heard today: 1) A weird sound (maybe the fans?). 2) Occasional engine sound (knock?) 3) brakes squeaked a couple of times even though they are new (replaced all 4 in 2012), maybe it was just the heat?, it didn't happen every time. I got two ideas today from being so focused on the grill block. The first is an added benefit to the grill block besides aero and warm-up time is my stock intake (which is sort of a CAI, its really close to the front grill) will take in hotter air. That increases knock potential, but I have a VVT-I engine, so I don't think that matters (maybe, thoughts?). I heard an unpleasant sound a couple of times, but I have never heard knock, so I don't know if it was knocking or not. The second thought was an ability to know if the fan is on. Like a little LED light that comes on when the fan is on. It could be really inconspicuous, since it probably won't be on very often, but would be useful, so you could know when/how often the fan is on. Unless of course an UG/SG has the ability to show fan on/off, then that would be the most useful Long post, but a lot to get off my chest! :) |
I live in South Florida, in the summer the cycling of fans at a stop light is normal on my car with the AC off, even without grill blocks. Several of my recent cars actually run warmer when the AC is off, this is cause by the continuous operation of the fan with the AC on. Even had one car the fans would run for a short period of time after the car was shut off. All that to say in order for you to know what is outside of normal for your car you need to know what is normal. |
http://ecomodder.com/forum/showthrea...led-24563.html Quote:
I hope that is enough. |
Somehow I thought that it was something more elaborate! :) |
Updated Grill Block
So after a tank of having the grill block, I decided since I didn't see any gain, I moved it to the front of the grill. I forgot to take pics of it, but it looked sooooo ridiculous! So I decided to get some black cardboard from a friend of mine who works at a former employer of mine (I used to work at a frame shop... lots of cardboard in a frame shop! and I know he always has black available). Best part was that it was freeeee!
So I put on the black cardboard, cut it to fit, rather than flat and straight on, sticking too far down past the bottom of the bumper. About half-way through the tank, I realized I blocked too much, so I took the upper blocks off. I figured those "holes" are a TON smaller than the bottom, so the bottom is probably better to block in my case. I am thinking about re-blocking the top, just not as much as last time. http://i1289.photobucket.com/albums/...ps75ad5aa4.jpg http://i1289.photobucket.com/albums/...ps04a8598f.jpg http://i1289.photobucket.com/albums/...psf375a364.jpg It's not the cleanest install, but the black looks waaaaaaaay better than the brown cardboard! Plus, being installed to fit, rather than just sitting over the top, it looks more like it's supposed to be there. One thing I thought of while I was cruising down the highway is that even though the block is in front of the support bars, it is still set back quite a bit into the bumper. http://i1289.photobucket.com/albums/...ps1d4e3b9b.jpg The block inset varies between an inch and inch and a half, so what I was thinking about doing is putting some sort of insulation behind the cardboard, to push it up and bring it flush with the bumper. My friend/former neighbor is remodeling my old house, so when he comes up with some scrap insulation, I can take some of that and fix it up to be more flush. The hardest part is going to be getting it flush with the front of the bumper, since it is different depths. I would appreciate any thoughts or ideas to make it better! Thanks! |
Foam+ black tape to make it flush rather than being inset would have a much more significant impact on air flow. Still, it's a step in the right direction. Check this post http://ecomodder.com/forum/showthrea...tire-2721.html out for an even easier and cheaper aero mod you may not have yet gotten to.
