Heh, that was not it. The one that I read did not give any details. I should have asked if any of you had made one.
Daox did and he described it here: I
Daox's 1997 Paseo Build Thread
He pulled the appropriate fuse, put a wire in each side, and attached the other end to an LED--I think.
If the fuse box is under the hood, what is the easiest way to run wires into the cabin?
I really do not know anything!
