grille mod
I have a rather flat, non descript grille block now on my '06 Dakota. My plan is to build a new block that will extend to the front bumper following the lines of the down sloping hood.
My question, to all of you aero gurus out there is this: On the horizontal plane, do I use the arc that would extend to the outside edge of the vehicle, or the arc that would end at the inside edge of the headlights?:confused: I know the best would be to totally redesign the front end into a smooth rounded hemishere, but I'm not quite to that level yet. So, waddaya think? |
The arc should go to the outer edge of the vehicle, and blend smoothly into the side
