EcoModder.com
-   The Lounge (https://ecomodder.com/forum/lounge.html)
-   -   Guess this signal (https://ecomodder.com/forum/showthread.php/guess-signal-11035.html)
NiHaoMike 11-17-2009 11:57 PM
Guess this signal
http://i49.tinypic.com/xe0w10.jpg
Can you guess what that signal is?
gone-ot 11-18-2009 08:39 AM
...OK, I give up, what is it?
dcb 11-18-2009 08:40 AM
vss?
moorecomp 11-18-2009 08:45 AM
I'm sorry, all I could think about when I read this was that new tv show "Big Bang". This could be one of the games they play: "Guess This Waveform".:D
NiHaoMike 11-18-2009 08:37 PM
No correct guesses yet. Please keep guessing.
bgd73 11-18-2009 10:42 PM
heartbeat
theycallmeebryan 11-18-2009 11:07 PM
Something to do with organic chemistry?
NiHaoMike 11-18-2009 11:26 PM
Technically, yes. But not really.
Arragonis 11-19-2009 08:04 AM
Me calling from what I think you on this planet call Mars ?
gone-ot 11-19-2009 09:04 AM
...hmm-m-m-m, that sorta points toward gasoline...maybe injector pulses?
...but, if true, then they're awfully "ratty" looking.
...I'd expect a 'drive' signal to be fairly "clean" looking, while a "return" signal could be "ratty" due to added noise.
wagonman76 11-19-2009 12:36 PM
I'm thinking it's from an O2 sensor.
gone-ot 11-19-2009 04:04 PM
...I didn't think the O2-sensor had a "dwell" state between it's "rich-vs-lean" voltage swings...just 'slam-bam' output.
alohaspirit 11-19-2009 07:54 PM
seismic chart on some electronic machine
NiHaoMike 11-19-2009 11:00 PM
Lots of interesting (and funny!) guesses but still nothing correct. Keep on guessing!
dcb 11-19-2009 11:09 PM
Its about clue time Mike.
NiHaoMike 11-19-2009 11:31 PM
Hint: Many modern electronic devices have signals similar to it. Even some cars, such as the Prius, have such signals.
Christ 11-19-2009 11:32 PM
Something to do with a computer chip?
I can't think of a sensor on a car that operates in a range where 292mV is the high signal, and -300mV is the low... unless I'm mistakenly reading the scale in quadrants, in which case the low would be ~50mV
Also, that entire waveform occurred over 154ms, or is that time between peaks?
tasdrouille 11-20-2009 05:46 AM
I know the answer, but I cheated. Am I the only one lurking over at cmpg?
NiHaoMike 11-20-2009 09:02 AM
Cheaters aren't allowed to play.;)
MetroMPG 11-20-2009 10:08 AM
Cheaters can't even find the answer! I even went over to CMPG and didn't find it.
moorecomp 11-20-2009 12:21 PM
I did. Shutterbug.
Christ 11-20-2009 12:25 PM
Camera flash bulb capacitor?
NiHaoMike 11-20-2009 06:21 PM
The guesses are getting even wilder! Keep on going!
And remember, cheating doesn't count.
dcb 11-20-2009 06:45 PM
Is it Ernest Borgnine ?
tasdrouille 11-20-2009 07:02 PM
Cheater :P
NiHaoMike 11-20-2009 08:25 PM
Originally Posted by tasdrouille (Post 140632)
Cheater :P
And wrong as well!
Christ 11-20-2009 09:25 PM
Al Gore's brainwaves? I'm Serial!
alohaspirit 11-20-2009 10:49 PM
the effects of Palin Book Signing Events on Bald Eagle Sightings?
NiHaoMike 11-20-2009 11:30 PM
I can tell you're all about to give up. So here's another hint: I consider that waveform as very special to me.
Christ 11-20-2009 11:31 PM
I don't stand by this guess, but heart beat?
NiHaoMike 11-20-2009 11:51 PM
It does have a little to do with a heart. Not a real one, though, but a symbolic ("Valentine") one.
Christ 11-20-2009 11:55 PM
Signal from a Radar detector? (Valentine One) :P
Umm... I give up.
NiHaoMike 11-21-2009 01:07 AM
Looks like my attempt to mislead you worked. So another nice try.
Another hint: Notice how the high part of the signal initially is relatively flat, then it drops down and fluctuates wildly, rises and falls while still fluctuating, and then goes nearly flat again.
It is definitely possible to make a radar detector that outputs that kind of signal, but I'm not aware of any that do. (Same goes for fuel economy instrumentation equipment.) A modified version of that kind of signal was once used for Internet access a long time ago.
bgd73 11-21-2009 11:27 PM
real time clock from a pc.
RobertSmalls 11-22-2009 01:08 PM
If you tell me how big the axes are, I'll take a guess. i.e. is that volts or mV, seconds or usec.
And a request for another hint: Does the signal typically repeat for seconds, hours, or years?
NiHaoMike 11-22-2009 01:44 PM
That kind of signal could potentially be used to synchronize computer clocks. Only it is much more common to use NTP now that 24/7 Internet access is popular.
It's voltage vs. time. The units are in the picture. It repeats many, many times a second.
gone-ot 11-22-2009 03:32 PM
..if it's in a computer, the shadow dynamic memory refresh cycle?
Christ 11-22-2009 05:56 PM
internet time beats?
RobertSmalls 11-22-2009 08:55 PM
The units may be there, but I can't read them. What's the frequency, Kenneth?
Christ 11-22-2009 10:28 PM
DC, 100mhz, M = 10usec, MPos = 154.2usec, 292mV
