Gurney Flap on a Pick-Up Truck
This thread is a "how to" on what NOT to do if you want to save gas.
Link: Rear Spoiler on Pick Up Truck - Experiment - Pelican Parts Technical BBS This modification will cost you gas, although it will add some tracking stability on the highway which I like very much. The crazy version: Rear Spoiler on Pick Up Truck - Experiment - Pelican Parts Technical BBS http://i184.photobucket.com/albums/x...20Up/GUR-8.jpg How it is today: Rear Spoiler on Pick Up Truck - Experiment - Page 2 - Pelican Parts Technical BBS http://i184.photobucket.com/albums/x...k%20Up/RS2.jpg http://i184.photobucket.com/albums/x...k%20Up/RS4.jpg The flip down hinge I installed two years ago has since rusted to a set angle. Should anyone do this, use stainless steel piano hinge from a boat supply store. The shorter Gurney flap will cost you about 1 mpg on the highway, but I like the added stability at highway speeds so it's staying. In Michigan we get black ice, and after a night of that pick-up trucks can be found in the trenches off the highway and in the grassy/snowy divided highway area. For this reason I'm keeping my Gurney Flap, it's a safety feature at this point. And like most safety features it costs a little in gas mileage. EDIT: The full photo album on this truck link................. S10 4x4 Pick Up pictures by kach22i - Photobucket Sample: http://i184.photobucket.com/albums/x...p/IMGP0581.jpg Yes, I also own and experiment on my hovercraft. |
I used to have a hovercraft, which I built. More info on it can be found at stonemarmot.com/rants » Sid’s Hovercraft (Data) and blog pages adjacent to this link. I did a lot of experimenting with my craft.
http://www.stonemarmot.com/images/trailer.jpg |
That ain't no Gurney flap.
1-2% of the airfoil chord, set at a right angle to the pressure side of the airfoil. You have no airfoil, and therefore no Gurney Flap.
I see that I have the same engine you used to have. Quote:
I've done the top part, but the base support plate is in the way of the bottom, and I don't know what is under there. Link to my experiment in progress (semi-disaster now that the foam is water logged): Hovercraft - Experimental Skirt Project - Boat Design Forums .................................................. ............ RE: Gurney Flap I understand that in a strict sense it must be attached to a wing, not a rear deck - thank you for the correction. I just want to point out that I'm not alone in stretching the definition. Gurney flap - Wikipedia, the free encyclopedia Quote:
2010 Ford Mustang Shelby GT500 rear spoiler Photo Car and Driver - (305268) http://www.caranddriver.com/var/ezfl...cd_gallery.jpg I'll just call it a rear spoiler next time.:) |
You do see that raised lip on the Mustang, and lack of same on yours right?
The difference I see is that mine is a whole lot taller. What do you see? Cheers, George/kach22i |
Look at the spiller on the mustang.... Then notice the black thing at it's edge, which is a gurney flap.
You have nothing more than a spoiler. |
Good luck. |
The lip on the Mustang spoiler looks like it would be more cosmetic. If I'm not mistaken, the Gurney flap's purpose is to assist the flow of air under a wing, keeping airflow attached at higher angles of attack.
http://insideracingtechnology.com/Re...gurneyflap.gif There's just dead air under the Mustang's spoiler there. |
