EcoModder.com
-   Saving@Home (https://ecomodder.com/forum/saving-home.html)
-   -   Had to hook up the mobile generator (Prius) this morning (https://ecomodder.com/forum/showthread.php/had-hook-up-mobile-generator-prius-morning-29380.html)
Daox 07-01-2014 01:53 PM
http://ecorenovator.org/forum/attach...701_062002-jpg
I had to lug out the mobile generator aka the Prius this morning to pump 2" of water out of my basement after a pretty big storm went through and took out power for ~13 hours. It was surprisingly easy to rig up quickly, and worked out quite well.
Full story: Had to hook up the mobile generator (Prius) this morning - EcoRenovator
Cobb 07-01-2014 04:25 PM
I thought you totaled your "generator"? Isnt this the "wifes" "generator"? :eek:
Daox 07-01-2014 04:32 PM
When I totaled the last Prius, I replaced it with this Prius. Our cars are our cars. We don't really have a mine and hers. We just drive whatever makes the most sense. She has the longer commute now, so she drives it.
Cobb 07-01-2014 07:47 PM
If I own a home with a basement, I dont think you can have enough devices to pump water out. Id make sure to have a few including a gas powered one and a big deep cycle battery with a trickle charger and inverter.
My sidekick has a 105 amp alt, but my insight is 70 amps. Puts a limit on the largest inverter you can use. :eek:
cRiPpLe_rOoStEr 07-02-2014 10:37 PM
Gotta agree with that. If I were living in a house with a basement (and I still consider to do that eventually), at least one engine-driven water pump for emergencies would be a must.
BTW eventually repurposing the drive system of a wrecked Prius as a gen-set might not be a bad idea at all :D
Cobb 07-03-2014 06:48 PM
Yeah, I had hoped Dax re purposed his/hers wrecked prius to a 220 volt generator with the mains in the rear ready to back feed a transfer box to his home. There was talks about doing something with an insight hacking the 3 cables from the ima rotor and govern the engine at like 1800 rpms.
