EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Has anyone tried Kuhmo Ecsta LX tires? (https://ecomodder.com/forum/showthread.php/has-anyone-tried-kuhmo-ecsta-lx-tires-4230.html)
me and my metro 08-01-2008 01:24 AM
I have found a set of 14" wheels that will fit my metro. And I found these on the Tire Rack web site. $253 for 4-- 185/60-14 plus local install, They are rated @ 51 psi and 600 A A. I thought I might try a set if anyone has had good results. Thanks
MetroMPG 08-01-2008 09:32 AM
What's on your car now?
Keep in mind that with a larger wheel/tire combo:
- you may be increasing rotational weight
- you'll be slighty increasing frontal area
- you may be decreasing Cd
me and my metro 08-04-2008 09:27 PM
The car has some winter tires in 175/70-13 size. Approximately 22.7 " tall and fairly soft rubber running at 44 psi. The Kuhmos are the same height and are a 51 psi tire. Just looking for a better quality long life tire. I only have 6- 13" wheels and don't want to dismount the winter tires.
