Old 08-01-2008, 02:24 AM   #1 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
Question Has anyone tried Kuhmo Ecsta LX tires?
I have found a set of 14" wheels that will fit my metro. And I found these on the Tire Rack web site. $253 for 4-- 185/60-14 plus local install, They are rated @ 51 psi and 600 A A. I thought I might try a set if anyone has had good results. Thanks
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 08-01-2008, 10:32 AM   #2 (permalink)
90 day: 57.73 mpg (US)
What's on your car now?
Keep in mind that with a larger wheel/tire combo:
- you may be increasing rotational weight
- you'll be slighty increasing frontal area
- you may be decreasing Cd
Old 08-04-2008, 10:27 PM   #3 (permalink)
The car has some winter tires in 175/70-13 size. Approximately 22.7 " tall and fairly soft rubber running at 44 psi. The Kuhmos are the same height and are a 51 psi tire. Just looking for a better quality long life tire. I only have 6- 13" wheels and don't want to dismount the winter tires.
Video: Can Skinnier Tires Increase Fuel Economy? Peakster EcoModding Central 67 06-06-2019 01:27 AM
List of Low Rolling Resistance Tires Daox EcoModding Central 57 05-13-2019 02:17 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-26-2016 12:39 AM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 05:24 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 10:25 PM
