EcoModder.com
-   -   Has anyone used Slick 50 or something similar? (https://ecomodder.com/forum/showthread.php/has-anyone-used-slick-50-something-similar-26702.html)
sully06 08-15-2013 09:48 PM
I've heard it can increase your fuel economy. By how much? guess that depends on the engine,wear,etc. Wanted to know if anyone out there has any real life experience. Thanks
ksa8907 08-15-2013 10:04 PM
I remember hearing bad things about such products but it has been probably 10 years so I don't remember details. Z-Maxx though is almost entirely mineral oil. Be sure to check the msds for those products.
fidalgoman 08-15-2013 10:24 PM
Google is your friend LINK
sully06 08-15-2013 10:30 PM
yeah I saw those but wanted to see if someone has recently done it. Thanks for the replies
euromodder 08-16-2013 06:40 AM
My dad used to run it in some of his cars - but that was way back in time ... 1970s or so.
He found they ran smoother, no solid MPG claims though he says they also used a bit less fuel.
justme1969 08-16-2013 07:21 AM
same as others
same as others not worthy of expense! If you do your own maintenance then a exact same alternative for 1/3 price is mystic lube. But you shouldnt need it and if you have a new- er automobile that runs thinner oil its not helping.
They did have an excellent ad campaign and sold tons of thier products.
Not snake oil pardon the pun but it should already be in a quality oil product.
Thats an 1980s - 90s thing better off looking intozymol or lucas products.
kach22i 08-16-2013 08:42 AM
I treated/ran Slick 50 in my 1990 Geo Tracker (bought new) for nearly 20 years before it died of rust and corrosion of the electrical system.
Engine failure was not what killed the Tracker, but most likely it was money wasted.
Miller88 08-16-2013 09:38 AM
If you want better gas mileage and are looking at oil, go with a 0w-XX synthetic. It's lighter when cold and will likely give <1MPG. You'll save less in gas than the oil costs.
some_other_dave 08-16-2013 12:43 PM
Just take one of your teflon cooking pans, and scrape the teflon off and dump it into your engine. Then add a half-quart or so of very very very thin mineral oil, or even diesel fuel.
There, you've just put Slick-50 in your engine! Congrats, you now have particles of a solid in the oil, which can accumulate and even clump together and clog oil passages in the worst case.
Teflon is a solid. If you grind it up fine, it's still a solid. It won't coat anything unless you prep the surface carefully and then treat it correctly and then perform a much more complicated process than "dump the crap into your oil".
Not worth it, and potentially harmful. IMHO.
-SoD
sully06 08-16-2013 02:07 PM
Thanks for the info
