Old 12-06-2018, 01:08 AM   #1 (permalink)
windshield visor, but drag reduction?
I for some reason have it in my head that I want to combine a cowl visor and a sun visor to attempt an effective windshield angle reduction without the whole cut, weld, re-glue hassle of actually moving the windshield.
Maybe something like this http://www.sarona.com/media/images/4..._93_94_95_.jpg with an open top?
This would be on my w126 mercedes, not a full size van fwiw. My hood is longer which in my head would give me more room to work that angle modification.
Old 12-06-2018, 03:23 PM   #2 (permalink)
aerohead uses a cowl deflector. Here's an early version:
I suspect the visor is a[n air] trap. Possibly a Gurney flap at the top of the windshield would suffice.
aerohead (12-08-2018), Xist (12-08-2018)
Old 12-06-2018, 05:21 PM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
If you really want an outside sun visor, you could do a sun visor doubling as a big turning vane to keep the air from overshooting the windshield/roof line
Something like this, turned on its side, all along the top of the windshield, trying not to increase frontal area too much
The Following 2 Users Say Thank You to euromodder For This Useful Post:
aerohead (12-08-2018), wdb (12-07-2018)
Old 12-08-2018, 02:45 PM   #4 (permalink)
Isn't that like the proposed spoiler for CUVs?
Old 01-02-2019, 06:46 PM   #5 (permalink)
While I've been thinking about this I converted an outboard engine cover into a hood blister. The thought was to modify the airflow toward my exhaust stack; now I'm thinking a sun visor with plexiglass between the two will effectively change the windshield angle. I'm slightly worried about being pulled over, but I think I should be able to make it pretty readily removable.
Old 01-02-2019, 07:51 PM   #6 (permalink)
Needs pix.
My VLVW design has a three-piece windscreen over the original windshield. It may be drawn as a plastic bubble, but more likely would be perforated sheet steel with some of the web drilled out and a hatch like an armored car in the driver's sightline.
Old 01-03-2019, 12:55 PM   #7 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
Or adapt it to pontiac firebird rear glass? ( but being it rear glass means you lose road-worthiness, at least here (but here it would be illegal anyway))
Old 01-03-2019, 03:07 PM   #8 (permalink)
Too bad we can't put blinds inside the windshield
Old 01-03-2019, 04:04 PM   #9 (permalink)
euromodder's Avatar
My VLVW design has a three-piece windscreen over the original windshield. .
Now reverse it
Old 01-03-2019, 09:56 PM   #10 (permalink)
A trick of perspective, the other end looks like this:
The tail disappears.
Rear glass doesn't pass DOT standards for a windshield.
aerohead (03-28-2020)
