Hatch Wing on 2009 Toyota Matrix
http://image.motortrend.com/f/photo_...+rear_view.jpg
http://www.motortrend.com/roadtests/.../photo_01.html Is this little rear wing going to help or hurt the cd? |
It looks like the spoiler is higher than the roof. If this is the case then it is bad for aero.
If you look at the 03-07 Matrix you can see that the spoiler on it follows and extends the taper of the roof line. That type of spoiler helps aero. |
http://www.polyshineauto.com/GRAPHIC...atrix-2003.jpg |
The hatch on the new Matrix is more sloped than previous years. A spoiler like this probably helps since it break the airflow away from the body in a straighter line. That usually helps Cd.
hurt
upswept rear wing
Hurt.
So far, the 'Hurt' vote seems to indicate that Toyota made a mistake on this one.
To this total novice aero DIYer, that looks like a wing for putting down pressure on the rear wheels. At the cost of a lot of drag. edit: Good news. I checked their site, and the "Hatch-mounted roof end spoiler" is not standard on the less expensive versions.. |
drag
