EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   Have you removed an aftermarket car alarm? Did the car start afterward? :) (https://ecomodder.com/forum/showthread.php/have-you-removed-aftermarket-car-alarm-did-car-40572.html)
Xist 11-06-2022 05:08 AM
5 Attachment(s)
So, there I was minding my own business, burying business rivals in the dump, when my alarm went off.
I got it to go off, but it started again when I tried to start the car, over and over again, for fifteen minutes.
The best part of being stranded at the dump with a blaring alarm on a car I couldn't start is that I saw a squirrel when I went to replace my temporary plate with a permanent one, so I didn't have one.
The alarm kept going off, I couldn't start the car, I didn't have a plate, and I was stuck at the dump.
This took a while, but I think it looks great! :)
https://ecomodder.com/forum/attachme...1&d=1667727073
I noticed this when I bought the car, but the flipper wouldn't have known anything about it:
https://ecomodder.com/forum/attachme...1&d=1667727107
Not only was I stranded at the dump, but one time my brother asked to go to the store. I said "We're taking Mom's car, but I need to get something out of mine." I unlocked the driver's door and the driver's only--and he sat in the passenger seat.
"How did you get in here?! Whatever, now I need to get something out of Mom's car."
When I turned my back the alarm went off and my brother had his hand on the steering wheel.
I finally got it to turn off, I went to grab the thing again, once more the alarm went off again, and my brother's hand was on the steering wheel again.
I had him get in Mom's car and it went off while we were away.
Everyone said to follow the wires, but I thought that would require removing the dash.
No, just the panel under the steering wheel.
Oh and all of this:
https://ecomodder.com/forum/attachme...1&d=1667727371
The car only came with one key, it isn't factory, and it was wearing out. It is actually twisted from needing to turn it too hard.
I couldn't see how far the wires went and where the alarm was mounted until I removed the center console and the trim above it.
It turned out it didn't go past the center console at all, so I absolutely didn't need to remove the glovebox, but I found this!
https://ecomodder.com/forum/attachme...1&d=1667727501
So, some dealership installed a tracker and for some reason hid a key.
These were all of the components that I found:
https://ecomodder.com/forum/attachme...1&d=1667727684
I didn't find a sensor, but 5 wires coming off of the harness were cut.
The screws were also missing from the steering column.
The first owner bought the car on 08/31/2005 and sold it on 03/05/2007 with 21,000 miles.
Who the heck trades in a car after 16 months and 21,000 miles?!
The second owner traded it in and the dealership auctioned it on 02/01/2021
with 96,379 miles.
It was auctioned again on 05/30/2022 with 104,057 miles--almost 16 months and 8,000 miles.
It sold again on 07/07/2022 with unspecified mileage and I finally bought it on 09-20-2022.
I am the fifth owner and the fourth in 24 months?
I keep wondering if there was some hidden problem which led people to get rid of it after a few months or a year.
I also wonder if it was repossessed.
Perhaps some complication from that resulted in people getting rid of it prematurely.
Xist 11-07-2022 01:08 AM
There are 155M Google results for "removed car alarm car won't start," so it probably would have been a better idea to just disable it.
I have read dozens of pages about it, but most people who ask for help don't report back, so I don't know what actually worked.
Someone said they missed a connector, another person found a 30-amp fuse looked good, but was blown, a third found a kill switch, a fourth found a "Clutch pedal stopper," and a sixth didn't reconnect all of the wires.
I disconnected the battery, disconnected all of the aftermarket wires, and spliced the wire for the starter back together, but just because there is a physical connection doesn't mean there is an electrical one.
I covered the cut insulation on the several small wires that had t-splices.
One person kept saying to test the starter, but that was one of many where they were abducted by aliens or something.
Piotrsko 11-07-2022 03:01 PM
Since I won't necessarily go away..... test the starter, see if it gets powered or grounded.
Xist 11-07-2022 06:56 PM
There is always a Shouty video!
1 Attachment(s)
Did someone indicate they wanted you to go away?
https://ecomodder.com/forum/attachme...1&d=1667862713
[turn down the volume]
https://www.youtube.com/watch?v=G0MCNOppasIThat's just a less interesting version of Kaylee's solution!
https://www.youtube.com/watch?v=00io4VSA6VwThis guy introduced me to Solder Seal Wire Connectors! Instead of crimping wires together, it releases a little solder, and then heat-shrinks the connection!
https://www.youtube.com/watch?v=xMqt5AoWPyI
Unfortunately, I can't get any before Friday and I need my car tomorrow!
Piotrsko 11-08-2022 10:07 AM
So you'd rather goof off searching for and posting odd replies than fix an issue that causes you angst? I see an issue here.
Xist 11-08-2022 10:34 AM
That you never clarified what the heck you meant with?
Yes, obviously.
Xist 11-08-2022 11:41 PM
It was a fuse! :D
I was trying to make a list of things to check.
Fuses were always among the first things.
Someone told me to check a fuseable link and while I was there I started checking the most likely fuses.
Apparently I blew fuse #17 under the hood, the 30-amp AM2 Starting system, "IGN" and "IG2" fuses. I swapped that with another fuse and she's alive! :)
I think that I will order the storage compartment from a 2004 and give myself a third cupholder.
Now I have a hole in that piece of trim, so I will start pricing that.
What else could I put there? :)
Xist 11-11-2022 01:08 AM
The car runs and drives, but the airbags, overhead lights, and radio are disabled,
and my car sounds like a chandelier! :)
I finally made an attempt to clean the inside of the windshield and it is better, but I need to do a better job.
There is still a chocolate or something streak.
When I put my car back together I kept getting some kind of residue on my hand.
I think whatever is on my windshield is also on the glovebox.
The car didn't have screws for the steering column, so I needed to order some, and I had difficulty reinstalling the first panel. I removed the screw from Mom's car so I could verify which it was, but apparently it didn't fit because another panel was supposed to overlap it, and the screw goes through both.
Piotrsko 11-11-2022 09:52 AM
If the previous owner was a chain smoker, that could be the residue along with a coolant leak fog. Both have a noticeable odor. Ammonia and or "409" peels it off like onion layers.
Xist 11-11-2022 07:11 PM
The car doesn't smell like smoke, but I think the previous owner was dirty.
I don't know that there was a coolant leak.
In previous cars I have periodically needed to wipe the inside of the windshield. I read the dash outgases over time and leaves a residue.
I am going to try glass cleaner and a microfiber cloth.
I forgot to mention that the power went out when I removed the key, but all of that was fixed when I swapped a fuse from my Accord.
My 1300 mom canceled and my Saturday mom canceled for 3 weeks, but her adult daughter was able to sit in for speech, so I drove out, and I had just enough time to drive to the recycling center half an hour in the other direction.
It is the only place that I know which is supposed to recycle glass, but the webpage lists an address, but says it is next to one thing, and across the street from another.
Those things were a couple of miles away, but they were apparently closed for Veterans' Day, so I wasted an hour, and was late for my last client for nothing.
