Ryland
that's pretty much my setup too and it seems to work rather well. it also still allows me to open the window when needed
skyl4rk
it's all relative. investing in double glazing will pay of in the long run, especially when windows need replacing anyway. i've claculated however that to break even using plastic insulation vs the insulated glass i have at the front it would take 150 years
not a fair comparison as the glass insulates about twice as good as traditional double glazing and i assume my plastic attempt is still a bit below that.
still as a quick and dirty solution the results where quite spectacular and comfort has been increased so much that i can only imagine my fuel usage will be much lower as well.
bottom line is that it seems a good idea to cover your windows, the increase in confort and energy savings are imidiately noticable
when the remodeling is done all windows should be high insulation double glazing
