On the heels of the failed Puegot 208, any other hybrid air cars in development?
https://www.caranddriver.com/news/a1...id-technology/
Or is a compressed air hybrid not possible at this time? Some articles had stated 141 mpg, I believe, had it made it into production. But since it’s a subcompact, it probably would never make it to America. Still, a novel approach to decrease gas consumption, without the cons of battery electric hybrids. |
Lacks infrastructure. You have to remove heat compressing the air and then heat the decompressed air. I remember discussing a research effort to resolve that a year or two ago.
I could use the site's Search function, but you're the one that cares. |
The problem with compressed air is about half the energy is lost to heat compressing the air. That's why batteries rule.
I've always thought of liquid air (or liquid nitrogen) and compressed air vehicles as having cold as a byproduct, which can be used for something like an air-conditioner. This is the opposite of ICEV's that have heat as a byproduct.
EV's don't produce much heat and no cold. So they need to pump heat in or out of the cabin if you want to be comfortable in hot or cold weather. |
I had an extra tab open so I tried the Search function. Fruitlessly. There was some University research gone commercial about extracting and storing the heat and using it to warm the decompressed air.
But I did find this article via DDG: solar.lowtechmagazine.com: History and Future of the Compressed Air Economy:Historical compressed air systems hold the key to the design of a low-tech, low-cost, robust, sustainable and relatively energy efficient energy storage medium. Quote:
Maybe it's worth mentioning that I keep pointing to the Scuderi Split-Cycle engine.
Scuderi Split-Cycle Engine That was 2008. IMHO his heirs squandered his intellectual property. Same way as Elio, they tried to develop their own proprietary inline four. But one could generate compressed air on regenerative braking and recharge at home from that babbling brook. |
Battery hybrid solves other problems too, like keeping the AC running while the engine is off. By electrifying everything, all systems can operate regardless of the ICE running. Compressed air would need a similar way to run accessories.
Or use a second small air motor for the accessories. |
If the tank is filled at home maybe the heat from compression can be used to heat your house or water.
And when operating in hybrid mode heat from the ICE could be put back into the air in multiple stages. |
You lose a lot of energy to heat when compressing air and require heat to expand it somewhat efficiently. That's why cordless tools and hybrid cars are running on lithium ion cells, not compressed air tanks. Only advantage of storing energy in compressed air is that pneumatic cylinders can be used for suspension and active aero |
