EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   Hello from CA (https://ecomodder.com/forum/showthread.php/hello-ca-4785.html)
craig5_12 08-27-2008 04:05 PM
Hello from CA
Hey all, (apologies for the long post)
Nice site, I hope to gleam lots of info off of here. I've recently moved and my commute has gone from 3 miles to 60 - ONE WAY, with about a 2500' elevation gain/loss. There aren't many stoplights but lots of hills and speed limits from 35 to 65.
My car is 1997 Accord EX, it's lowered about 1.5" and has an aftermarket intake. It has 225 series tires on it now, but when they wear out, I'm getting the thinnest possible to reduce rolling resistance.
I've been tracking my mileage for about 10k miles now and the worst I've done is around 32mpg, I started implementing some better driving habits (coasting with engine on and off, shifting around 2500rpm, driving the speed limit, trying not to brake, etc..) with just changes to my driving habits I've increased the MPG to about 37.5mpg. My goal is to get to 40 without much assistance and then push up from there with HHO, EFIE, 02, etc..., and I'm almost there!
SVOboy 08-27-2008 04:18 PM
Man, that wasn't a great move! Brutal commute!
Welcome to ecomodder! Do you have a scangauge or mpguino yet?
craig5_12 08-27-2008 04:27 PM
Yeah, it's tough, but my mortgage was cut in half because of it...well almost in half...I get to make up the rest in gas...
No, no scanguage yet...what is a mpguino?
craig5_12 08-27-2008 04:36 PM
Nevermind, I saw the link to the mpguino...I'm more mechanically inclined than electronically...but I can solder a little bit so I might have to give this a try! I guess I better add that to my To-Do list...
cfg83 08-27-2008 05:33 PM
craig5_12 -
Welcome to EM! I feel your commuting/mortgage pain, even if I only have to go 35 miles one way. I am guessing you must love the drive down and cry all the way up hill.
CarloSW2
craig5_12 08-27-2008 05:49 PM
Any commute is a bad one in my eyes, although it has introduced me (now) into the world of hypermiling and I'm glad for that! I long for the days I can walk or ride a bike to work again...
The drive down is pretty cool though, I need to calculate the miles I actually drive with the engine off!
This forum is great and I look forward to learning lots and sharing what I can!
craig5_12 09-02-2008 04:34 PM
Well, I got almost 42mpg on my last fill-up! I guess I hit my first goal...I better set my sights on 50mpg now...and all this with just adjusting my driving style! Grill block, wiper delete, mirror delete and thinner tires coming up...
Clev 09-02-2008 05:16 PM
Nice work! I just started seriously Ecodriving my '90 EX, and I'm up to 32 mpg, so I have some work. I guess I'll be looking at a '97 when this one finally dies!
I assume you have a manual transmission. What RPMs do you turn at 65 in 5th? I think mine's way too high, and that's contributing to the problem.
Tim
craig5_12 09-04-2008 06:38 PM
Tim
Yeah, it's a manual. The manual coupes seem to be kinda hard to find for this year, I got lucky I guess because I really wasn't looking at FE when I bought it 8 years ago!
I don't usually drive 65 but for your sake I did today :thumbup: and I was turning at about 2600...hope that helps! Not sure what tranny's are available for the '90 model. I know for the '91 on up the F22B1 engine and tranny combo (what I have) is a direct replacement. The prelude Type S even had a LSD...The H22 engines also fit but I don't think they're as FE.
My buddy had an '89 and he changed the fuel filter and increased his mileage considerably...if you haven't done that yet, I'd try it and see if it helps! Good Luck!
Clev 09-04-2008 06:50 PM
I'll try that. I already picked up a replacement O2 sensor off eBay ($10!), so I'll get a fuel filter as well. 34.2 mpg at the last fillup, and still working on it!
