Hello from Kentucky
I have been lurking on here for a while and figured I'd say hello. I have a 2014 Chevy Cruze Turbo Diesel and have been pretty impressed with the fuel consumption so far. The car came with a few aerodynamic improvements( underbody aero panels, active lower grill shutter, lower ride height) and I've added an upper grill block.
I have a 180 mile round trip daily commute, so I rack up the miles pretty quick. Most of my drive is highway and interstate and the car loves it. I look forward to learning more from everyone on here and getting the most out of my car. |
Welcome aboard. Getting the most out of your car (mpg) is important. However. Getting the most out of your car would include not wearing it out. 180 miles x 5 days = 900 miles per week 900 miles x 4 weeks = 3,600 per month 3,600 x 12 months = 43,200 miles per year 3.5 hrs per day driving x 240 days = 840 hrs. 840 hrs. / 40 hr. work week = 21 weeks ^^^Wow. :eek:^^^ Maybe you should consider moving closer to your job or find something closer to your present home. Check this out. The True Cost of Commuting Have a Great Day.... :) > |
Holy cow man, what part of Kentucky do you drive? :eek:
I grew up in northwest Kentucky right on the Ohio river, and I can't think of any area you could drive that far and not go through hill country. I have to agree, you're wasting a lot of your life driving. If the situation isn't easily changed, I would at least try to find a rider to share the drive and the gas cost. Even if you picked a rider up halfway through, or left your car at somebody's house you'd get a lot of help on gas and way less miles on the car The farther you commute, the more sense it makes to carpool |
Welcome to the site!
Excellent ideas by the others guys so far, and I agree with both. You're one of the very few we've heard of with the Cruze diesel. What kind of mileage are you getting with it currently? |
welcome!
also, increase the psi in the tires to 40+ Also, since you drive on th freeway a lot, consider increasing the diameter of the tires on your next purchase. it will reduce the rpm at cruising speeds and get better mpg. When your ready to buy tires, give a shout and will get you more info. |
The car has a lifetime milage of 43.3 mpg. A single best tank of 937 miles @ 52.7 mpg. If I stick to the commute the mileage is usually in the low 50's and upper 40's per tank. If I have to run errands it will drop off pretty quick. The city mileage isn't bad at around 30 mpg. |
I like the idea of running taller tires, I will definitely be doing this mod when the time comes. At interstate speeds of 71 mph the engine runs at 2000 rpm. |
