02-18-2016, 09:41 PM
Hello from Kentucky
I have been lurking on here for a while and figured I'd say hello. I have a 2014 Chevy Cruze Turbo Diesel and have been pretty impressed with the fuel consumption so far. The car came with a few aerodynamic improvements( underbody aero panels, active lower grill shutter, lower ride height) and I've added an upper grill block.
I have a 180 mile round trip daily commute, so I rack up the miles pretty quick. Most of my drive is highway and interstate and the car loves it.
I look forward to learning more from everyone on here and getting the most out of my car.
02-19-2016, 09:51 AM
Welcome aboard.
Getting the most out of your car (mpg) is important.
However.
Getting the most out of your car would include not wearing it out.
180 miles x 5 days = 900 miles per week
900 miles x 4 weeks = 3,600 per month
3,600 x 12 months = 43,200 miles per year
3.5 hrs per day driving x 240 days = 840 hrs.
840 hrs. / 40 hr. work week = 21 weeks
^^^Wow.  ^^^
Maybe you should consider moving closer to your job or find something closer to your present home.
Check this out.
The True Cost of Commuting
Have a Great Day....
The Following 3 Users Say Thank You to redneck For This Useful Post:
02-19-2016, 10:37 AM
Originally Posted by redneck
Welcome aboard.
However.
^^^Wow.  ^^^
Check this out.
Man, that article was a real eye opener! I appreciate the new perspective. I have a lot to learn. I never really put all that commute time on paper and really looked at it. I knew it was a lot of time and I was always kind of afraid to do what you did and add it up like that. Thank you showing me what I am truly spending on this commute.
Sorry, new users are not permitted to post links in their signatures.
02-19-2016, 01:46 PM
Holy cow man, what part of Kentucky do you drive?
I grew up in northwest Kentucky right on the Ohio river, and I can't think of any area you could drive that far and not go through hill country.
I have to agree, you're wasting a lot of your life driving. If the situation isn't easily changed, I would at least try to find a rider to share the drive and the gas cost. Even if you picked a rider up halfway through, or left your car at somebody's house you'd get a lot of help on gas and way less miles on the car
The farther you commute, the more sense it makes to carpool
02-19-2016, 01:59 PM
Welcome to the site!
Excellent ideas by the others guys so far, and I agree with both.
You're one of the very few we've heard of with the Cruze diesel. What kind of mileage are you getting with it currently?
02-19-2016, 02:06 PM
welcome!
also, increase the psi in the tires to 40+
Also, since you drive on th freeway a lot, consider increasing the diameter of the tires on your next purchase. it will reduce the rpm at cruising speeds and get better mpg.
When your ready to buy tires, give a shout and will get you more info.
02-20-2016, 09:30 AM
I commute from Pulaski County to Lexington. I did car pool with a guy for a few years. The problem is we work a "flex schedule" and not everyone has set hours and works the same time. Some weeks I work 4, 10 hour days, and others I work 5, 8 hour days, or a combination of 12 and 5 hour days. It was too hard to be on the same schedule as someone else that lived in my general direction.
02-20-2016, 09:38 AM
I agree with everyone's ideas. I have never really looked at it in this way. I was always just concerned with getting the best mileage from the car and not really looking at reducing the mileage to save fuel costs/time. I have a lot to think about.
The car has a lifetime milage of 43.3 mpg. A single best tank of 937 miles @ 52.7 mpg. If I stick to the commute the mileage is usually in the low 50's and upper 40's per tank. If I have to run errands it will drop off pretty quick. The city mileage isn't bad at around 30 mpg.
02-20-2016, 09:46 AM
#9 (permalink)
Originally Posted by mcrews
welcome!
I run my tires at the maximum sidewall pressure of 51 psi cold. On the interstate when warmed up the tires will creep up to 56 psi.
I like the idea of running taller tires, I will definitely be doing this mod when the time comes.
At interstate speeds of 71 mph the engine runs at 2000 rpm.
