Hello new here 2008 Suzuki SX4 Sport Sedan MT
I have been checking out the site. I'm amazed at the results some have had with there mpg. I live in just outside of Denver Colorado I comute 37 miles each way to work. I grew up in Vegas and have heavy foot most of the time. So it has been a real difficult for me to change the way I drive. I love to drive and I like to drive fast. So my plan is to use the money I save on gas for toys for the car. My average mpg was 32.4. All I have done so far is change they way I drive and have managed to bump my average to 37.1. That seems to max with just driving habits. 95 percent of my drive is all highway. I will still put my foot into it when I head up to mountains since that when I find driving most enjoyable. The only mod I have done to the car is a K&N air filter. So I am looking for Ideas to save money on the daily grind. I must note that I'm not willing to go with out the creature comforts I spend way to much time in the car each week to not be comfortable. Thank you in advance for you input.
could try a scanguage? I've been reading about suzuki alot lately. Don't think I'll get one anytime soon but they seem to be very nice cars. Like the sx4 very much. Is your sx4 awd or fwd? what trim level, manual or auto? Welcome.
It is a FWD MT transmission. Happy to report my average is up to 38.2, my car now displays avg mpg as well as mpg on the go. I have the convienience package. Power everything. Mods I am considering is tires, underbelly pan if if i can justify the effort. Adding fog lights they will fill the cavities from not having them. maybe reprogram the ecu if it does not cost to much. I figure that these enhancments will allow the car to to save money on the drive to to a from work must will make the car faster when I want to have fun on the mountain roads
Since your mostly highway. Aeromods will definitely give you the bang for the buck. Belly pan, tire pressure, grill block to start and try to slow down as much as you can stand. What's the highway EPA for your car?
Specs on the car is as follows
2.0-liter, 143-horsepower (at 5800 rpm) and 136 lb-ft of torque (at 3500 rpm) EPA estimates are 22 city and 30 highway Engine Type dual overhead cam 16-valve aluminum alloy inline 4-cylinder Engine Size 2.0 liters / x cu. in. Horsepower 143 @ 5800 rpm Torque (lb-ft) 136 @ 3500 rpm Transmission 5-speed manual Wheelbase / Length 98.4 in. / 177.6 in. Curb Weight 2668 lbs. Pounds Per Horsepower 18.7 Fuel Capacity 13.2 gal. Fuel Requirement 87-octane unleaded regular gasoline Tires P205/50 VR17 Dunlop SP Sport 7000 Brakes, front/rear vented disc / solid disc, ABS and EBD standard Suspension, front/rear independent MacPherson strut / semi-independent torsion beam axle Drivetrain transverse front engine, front-wheel drive PERFORMANCE EPA Fuel Economy - miles per gallon city / highway / observed 22 / 30 / 27 0 to 60 mph 9.2 sec Fifth gear in this car is a real disipointment and is not geared properly for the states most of the areas I drive the speed limit is 75 so at those speeds the fuel economy drops considerably. So my plan was to change the tires that are now worn enough to not be safe for the upcoming winter from 205/50/17 to 225/55/17. I know I may take a small hit for the wider size but that is ok since it will enhance grip in the turns and that is where I typically push the fun factor. Since the tire is a little taller it will fill the gap between the tire and fender. I think it will help the final gearing a little, do I have that right? There is close to 4 inches of gap. I'm at 36000 so when I hit 60000 and the stock struts are worn out I wll be droping the ride 2.5 inches maybe 3. Will blocking the lower opening on bumper make that much of a difference? How much can I gain from underpanning, the entire car? Any mods I do has to look good so I'm at a loss on how to block the lower bumper opening it is pretty big. I will not block the upper portion I will not risk overheating the car. I have a 100,000 mile warranty to keep in mind. |
I gained 7% fuel economy with a 50% grill block, a windshield wiper block, and a smooth front and rear belly pan. All of the mods were done with coroplast, think campaign signs. The ones I got had a vynal layer on them that peeled right off, leaving a nice white surface to work with. Doing an upper grill block is preferable (leaving the lower one open/partially open) as it screws less with your aerodynamics. Pop your hood an look at where there is a radiator, in my car, there was only a radiator on one side, so the other side got the grill block.
Your taller tires would work well with better aerodynamics, since the lower load seen (due to improved aerodynamics) means less power needed (so taller gearing is preferable). Just remember to not go TOO high, as you still need to be able to accelerate. Also, remember that you are going to be screwing with the speed reading you are getting. My speedo is off by 6% due to the larger tires I am running. |
What rpms are you running at 70-75?
wyatt,
thanks for the info so it looks like I have some things to do I will do my research and think it to death, what ever i do will have to be cheap and look good. I am not willing to uglifiy my car to mpg. My avg is now up to 39.5 so i am really pleased with just driving habits on the daily grind to and from work. i have not played with air pressure in the tires yet. i forgot to check on the RPM's I will do that on the way home. I did not hit 70 this morning i was following a fed ex truck (2.5 secs behind him) most of the way so i did not exceed 65. I have had really good luck letting other cars break up the wind for me. so if it wasnt for that i do not think my results would be nearly as good. I always maintain a safe distance according to the laws and doing so is still helpful. |
70mph 3000RPM 75mph 3200RPM 80mph 3500RPM 85mph 3700RPM |
Your already 30% over highway EPA. Some people take quite awhile to get there. Took me 1.5years to get 50% over EPA. So you are well on your way.
Read up on some of the advanced hypermilling techniques. Now that you have the basics the advanced ones "might" bring some fun to driving without having to "go-fast". I agree with the others your most bang for the buck will be lots of little aero changes. Each one maybe only a percent but do 5-10 of them and they start adding up. |
