EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   Hello there! (https://ecomodder.com/forum/showthread.php/hello-there-29829.html)
The_Jed 08-25-2014 10:23 AM
Hello there!
https://scontent-a-ord.xx.fbcdn.net/...55958803_n.jpg
My '92 LSC with a bit of snow on top and an '87 LSC I no longer own in the background. It has 110,000 miles on the clock ans so far my best average MPG driving to and from work is 17.7. (My avatar pic.)
https://scontent-a-ord.xx.fbcdn.net/...39581994_n.jpg
This is my '97 Impreza. I've owned and beat on it for over a decade and it currently has 172,000+ miles. The best MPG driving to and from work so far is 31, IIRC. It usually averages around 27 mpg in the summer and 24 mpg in the winter.
https://scontent-a-ord.xx.fbcdn.net/...42842099_n.jpg
The wife's 3.0R stealth wagon. These things are FAST!!! Averages around 22 MPG in mixed driving.
Like many other noobs I've lurked here for quite a while, just soaking up information. While I don't see myself ever employing extreme hypermiler driving techniques I do make a conscious effort to drive more smoothly and conservatively and I will definitely be making some efficiency and aerodynamic improvements.
MetroMPG 08-25-2014 02:20 PM
Welcome to the forum!
cRiPpLe_rOoStEr 08-25-2014 07:46 PM
Is that Lincoln fitted with a 302W, right?
The_Jed 08-26-2014 01:18 AM
@MetroMPG: Thanks!
@cripple rooster: Yep, the exact same engine that went into the '92 Mustang GT.
cRiPpLe_rOoStEr 08-29-2014 03:04 AM
Have you never considered to retrofit it with a newer, smaller engine, such as the Essex 4.2L V6 out of an F-150?
The_Jed 09-04-2014 10:10 AM
No, but I have considered trading it in on something more efficient. :)
cRiPpLe_rOoStEr 09-05-2014 10:26 AM
That makes sense. Unless you had some kinda special feelings for that car :D
The_Jed 09-07-2014 11:32 PM
Funny you should say that. I am very attached!
cRiPpLe_rOoStEr 09-28-2014 07:20 PM
So it might be worthwile to use the car as a base for a fuel-savings oriented project. I guess you have been aware of an Edsel retrofitted with a 2.3L Georgia OHC Turbo...
