Help me pick headlights
OK, headlight time.
Pic of truck for paint color: http://i810.photobucket.com/albums/z.../trucking3.jpg Option 1: http://i810.photobucket.com/albums/z...g60/111195.jpg Option 2: http://i810.photobucket.com/albums/z...g60/111196.jpg Option 3: http://i810.photobucket.com/albums/z...g60/111205.jpg Option 4: http://i810.photobucket.com/albums/z...g60/111206.jpg Grille and bumper will be light colored wood with a bright finish What do you all think? |
Wow, 20 views and no votes. No love for the anzo headlights?
Are one and two projectors? I'd take those over standard halogen housings any day.
go for the projectors, either one is fine. its night and day...lol the light output
nice pun there krayzie
Wow, It's been two weeks plus and finally I get some replies and votes to the poll!!
I had given up on you guys. I went with these at Amazon. http://www.amazon.com/111065-Project...9267601&sr=8-1 |
make sure to post up some pics once done
What bulbs do those take? There are some very nice bulbs out there, depending on what bulbs the low beam and high beam take.
The low beam is a sylvania H7 55W I am going to use these for a while and see before I get different bulbs. I almost returned them to Amazon because the fit is not that good. My wife does think they look good, so I am doing some customization to improve the fit, and cutting some metal in the fender to access the adjuster screws and high beam bulbs. As it is you'd have to remove the headlights to replace a high beam, and also to reach 2 of the 3 adjusters. This is not so much a fault of light design as it is a fault of the trucks original lights. It was a single bulb and therefore only had enough access hole to allow the single bulb. |
You are driving a MOPAR!!! Build a slick George Poteet 2nd gen. 'Cuda BLOWFISH Bonneville type front end w older Integra small round headlights all clean and flush mounted....dare to be different!
