EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   help !!mpguino was working until yesterday (https://ecomodder.com/forum/showthread.php/help-mpguino-working-until-yesterday-20825.html)
paulcookie 03-04-2012 10:53 PM
Hello if somebody can help my mpguino it was working fine until yesterday I don't know but for some reason now mpguino in the part where says GH before was saying GH000.13 and up but now suddenly says GH012.53 to GH012.58 so I don't know why and I check again all the connections and is fine the only thing that I notice is that all my injectors now has 12v even where it was connected the mpguino before it was 0v where I connected and now is 12v so how come? why ? I hope somebody can help me..
Paul.
Ecky 03-04-2012 11:47 PM
Is only GH weird, or are all of your injector-related values wrong?
It's possible that you have a short somewhere, letting current past the resistor.
paulcookie 03-04-2012 11:57 PM
Well I'm trying to check if there is any ground or short in somewhere but until now I can't find it.. the most important is that I now its not a serous problem with the injectors because from the ground ( from injectors )to to the Body its not shorten I put in buzz on my MM and there was not shorten ( otherwise will flood the engine )so the problem is in some where that I can not find it...I hope somebody can help me with this..
Paul..
dcb 03-05-2012 05:58 AM
I would go through and set the menu parameters back to their original values maybe.
paulcookie 03-05-2012 05:14 PM
Thank you for the reply.. if you don't mind to give me what is the original parameters I don't have it and I try to find but there is not... thanks...
Paul.
