Hi people! I'm Xavi from Portugal!
Hi guys!
I’m Xavi from Portugal, and I have a 8th generation Civic, the 1.8 i-vtec sport version. I have been following the ecomodder.com for a while now, but only today decided to register. I have been using many hypermiling techniques for some years…it all started with a 1.5 vtec civic with D15Z6 lean burn engine, that has an ECONO light. I have been learning more and more along these years and improving my FE. I’m using a Scangauge II for 6 months know. Very useful. But the numbers aren't that good for some reasons: - I simply can’t stand driving with over inflated tires: the car has a very stiff suspension, together with 225-45-17” tires, it gets even worst. Also because they are so large it causes to much drag (thinking of changing to 205-55-16”); - My average speed per tank is too low (33 km/h or 20.5 mph), my daily commute is on B roads, with 2 traffic lights, 2 stop signs, and 2 roundabouts, and with ups and downs (which I use to P&G) and 5 miles to work, 3 miles to lunch, 3 miles to work, and 5 miles back home… In the chilly weather the engine doesn't even warm up. Also I hardly drive on motorway, sometimes several months without any motorway… - Thinking of a engine heater, but the car garage is far from a electric plug… - Don’t want to put a grill block cause it looks so awful, don’t know if it’s possible to install a grill block inside the bumper so it doesn't show from the outside?! Still I can get 37-40 US mpg on the summer, and 33-34 US mpg on winter. Honda claims a 35 US mpg on combined cycle for this car, so I think with this short trips, my mpg it’s not so bad… Is it? |
Welcome to the site!
Yeah, that isn't bad mileage considering your short commute. You should definitely focus on any modifications that promote a faster warm up though. A grill block on the inside will help achieve that. |
Thanks, I just edited the post cause I posted the uk mpg, and not the US mpg...
You know, here we use lt/100 km :) |
Welcome xavi -
When you pulse & glide, are you shutting the engine down, or idling? I would definitely investigate a "stealth" grille block (inside). |
with engine on...
I will get a better look how to do it, cause the cold is coming... |
Here is a video of my best tank... It was a year ago... Looking forward next Summer to beat this numbers by far, because I changed my wheels this weekend and change from a large heavy 225-45-17" wheels for a much lighter and thinner 205-55-16". It was a big difference in driving: much more comfort, lighter steering, and also I put 4 new low rolling resistance tires (yokowama c-drive 2 - check video), so it seems... :)
https://www.youtube.com/watch?v=yGSEtpZ5FpE Rolling resistance comparison: https://www.youtube.com/watch?v=NwuL04qbNVY |
