Old 09-09-2014, 02:11 PM   #1 (permalink)
Hi people! I'm Xavi from Portugal!
Hi guys!
I’m Xavi from Portugal, and I have a 8th generation Civic, the 1.8 i-vtec sport version.
I have been following the ecomodder.com for a while now, but only today decided to register.
I have been using many hypermiling techniques for some years…it all started with a 1.5 vtec civic with D15Z6 lean burn engine, that has an ECONO light.
I have been learning more and more along these years and improving my FE.
I’m using a Scangauge II for 6 months know. Very useful.
But the numbers aren't that good for some reasons:
- I simply can’t stand driving with over inflated tires: the car has a very stiff suspension, together with 225-45-17” tires, it gets even worst. Also because they are so large it causes to much drag (thinking of changing to 205-55-16”);
- My average speed per tank is too low (33 km/h or 20.5 mph), my daily commute is on B roads, with 2 traffic lights, 2 stop signs, and 2 roundabouts, and with ups and downs (which I use to P&G) and 5 miles to work, 3 miles to lunch, 3 miles to work, and 5 miles back home… In the chilly weather the engine doesn't even warm up. Also I hardly drive on motorway, sometimes several months without any motorway…
- Thinking of a engine heater, but the car garage is far from a electric plug…
- Don’t want to put a grill block cause it looks so awful, don’t know if it’s possible to install a grill block inside the bumper so it doesn't show from the outside?!
Still I can get 37-40 US mpg on the summer, and 33-34 US mpg on winter.
Honda claims a 35 US mpg on combined cycle for this car, so I think with this short trips, my mpg it’s not so bad… Is it?
Last edited by xavi; 09-09-2014 at 02:19 PM.. Reason: Posted UK mpg, now edited to US mpg
Old 09-09-2014, 02:16 PM   #2 (permalink)
Welcome to the site!
Yeah, that isn't bad mileage considering your short commute. You should definitely focus on any modifications that promote a faster warm up though. A grill block on the inside will help achieve that.
Old 09-09-2014, 02:21 PM   #3 (permalink)
Thanks, I just edited the post cause I posted the uk mpg, and not the US mpg...
You know, here we use lt/100 km
Old 09-24-2014, 08:55 PM   #4 (permalink)
90 day: 51.82 mpg (US)
Welcome xavi -
When you pulse & glide, are you shutting the engine down, or idling?
I would definitely investigate a "stealth" grille block (inside).
Old 09-26-2014, 04:12 AM   #5 (permalink)
with engine on...
I will get a better look how to do it, cause the cold is coming...
Old 11-22-2015, 03:39 PM   #6 (permalink)
Here is a video of my best tank... It was a year ago... Looking forward next Summer to beat this numbers by far, because I changed my wheels this weekend and change from a large heavy 225-45-17" wheels for a much lighter and thinner 205-55-16". It was a big difference in driving: much more comfort, lighter steering, and also I put 4 new low rolling resistance tires (yokowama c-drive 2 - check video), so it seems...
Rolling resistance comparison:
Old 11-23-2015, 04:40 AM   #7 (permalink)
Check those Webasto fuel-powered heaters.
