EcoModder.com
-   -   HID xenon lights to reduce electrical load (https://ecomodder.com/forum/showthread.php/hid-xenon-lights-reduce-electrical-load-14545.html)
cycleguy 09-14-2010 02:11 AM
My 1994 Geo Metro has an underdrive pulley and a super tiny 'race' battery. Because of this, P&G and EOC doesn't work very well for me. I have been working on reducing my car's electrical load by removing things like the stereo, dash and dome lights, etc... Also, I removed the passenger side vents and blocked up the air ducts so that I don't have to put the fan up so high to get air on the driver's side.
But that's not what I came here to talk about... (Arlo Guthrie)
I realized that one of my largest electrical loads in the car are the headlights. I don't really use them when it is light out, but I drive early in the morning and late at night so I have to use them most of the time. I looked into LED lights, but found that they are either too dim or too expensive(200/bulb without drivers). Then, I stumbled upon HID lighting systems. These use high voltage to react in a xenon tube. The light is much brighter and uses up to 35W per bulb. I happened to know a guy who owed me a favor and he knows a guy who has an HID ballast kit I can have. It is made by Philips and seems to be fair quality. I just purchased the bulbs online tonight for 20 bucks so I should have all I need to check this out this weekend. It may not be a huge power savings, but if nothing else I will get more light and less heat from my bulbs. Obviously I am not the first to do this to a Metro, but I thought I would share anyway. I will let you know how it turns out.
tollo 09-14-2010 03:55 AM
I have dual xenon headlights and daytime running lights. High beam 4 x 35W and 2 x 35W for lowbeam. I would use 25W xenon bulbs (or ballast), but those are hard to get. You can get double of lumens from 35W xenon compared to 60W halogen. So I think, that 25W xenon is more than enough in most cases.
There is always some kind of prolems with vehicle regulations. Usually you can't totally legally replace your halogens bulbs with xenon replacement kit. Check that your assembly won't glare other drivers.
Vekke 10-04-2011 02:59 AM
I installed also Xenon H4 hi/lo beams last weekend and oh boy how great they are. On the dark I can see almost 100 meters longer and they also save fuel!. I cannot imagine that I would go back to using old halogen lamps in my car anymore. Half of the year Finland is very dark so if I can avoid even one moose crach or minor collision they have earned they price.
jakobnev 10-04-2011 07:52 AM
I still haven't seen anyone selling a kit they claimed were legal. That said, i wonder if it is possible to reduce the power of the kit to say 17w or if a certain bulb will only work at it's rated power.
http://www.youtube.com/watch?v=yVuSSdZNsZw
mcrews 10-04-2011 10:57 AM
cycleguy,
By installing the a hid system in a halogen designed lamp, you will increase the GLARE not increase the useable light.
THe basic issue is the hot spot on the bulb.
http://i678.photobucket.com/albums/v...s/bulbs001.jpg
The reflective pieces inside the lamp (chromed) are designed SPECIFICLY for the halogen bulb. IT IS IMPOSSIBLE (REALLY) to successfully install an hid lighting system into a halogen lamp.
Can it be done.....ABSOLUTELY. 1. illegally and 2. see above.
Yes, there are thousands of Plug n play kits on the internet. That doesnt mean that they correctly reflect the light.
Go to HIDPLANET.com and spend a couple of hours reading up.
Here is how an hid light should look. There HAS to be a cutoff.
http://i678.photobucket.com/albums/v...es/9-23-11.jpg
there is no cutoff inside your lamp. (for starters......let's not even discuss the glare to oncoming drivers.)
just to givr you an idea.
Here is an HID fog projector designed for an hid systerm.
THe bulb, while in 'correctly' is not perfectly centered inside the housing. thus the is 'some glare' above the cutoff.
http://i678.photobucket.com/albums/v...s/IMG_2161.jpg
All that glare is shoot up and at oncoming drivers.
this is that same lamp corrected with very slight adjustments
(ignore that it is higher on the wall. adjustments have to be made while the assembly is uot of the car)
http://i678.photobucket.com/albums/v...s/IMG_2211.jpg
mcrews 10-04-2011 11:06 AM
Next,
your laamp is plastic and called 'a reflector' for halogen buldb
here is an example...see how you can see the bulb in the center and the lens is really just the plastic cover?
http://i678.photobucket.com/albums/v...rilles/024.jpg
Here is the exact same 'houising' but designed specificlly for hid. see the 'dull looking lens behind the plastic lens
http://i678.photobucket.com/albums/v...s/IMG_2142.jpg
Hid lamps are metal and called 'projector' they have a factory ground optically ground lens.
http://i678.photobucket.com/albums/v...es/lens002.jpg
http://i678.photobucket.com/albums/v...s/IMG_2155.jpg
Finally, the hid has a metal body so that the heat generated by the hid bulb wont melt it......
your lens is plastic...........think about it........
Finally, YES, the BASE of the HID will fit into the base of the halogen lamp.
But that DOESNOT MEAN IT WORKS CORRECTLY!!!!
Vekke 10-04-2011 05:16 PM
If you want legal HID lamps go to Hella | Homepage.
Your lights should have D marking in them to be able to use these aftermarket kits, legally
That would cost about 2500€ total. Now if in finland at the moment about 5% has this kind of illegal HID kits should that mean 5% more accidents according to that video? I can also say it will not work perfectly but many other things can also distord the halogen lamps. Biggest issue which affect the safety is the user and how he adjust the driving lights heigth.
Anyway it was a good video on the topic ;).
I am disturbed maybe once a month about someones drive lights. Some of those are also regular lights which has just been adjusted wrong. You are not supposed to try to read the other cars licence plate number when you face it on the road...
mcrews 10-04-2011 05:53 PM
tolo,
you understand that YOU car came with HID.....correct?
And the the METRO DID NOT come w/ HID, correct?
And so your recommendation is (well illegal) complete off base, correct?
And yes, you have a disclaimer......but........
mcrews 10-04-2011 06:02 PM
Vekke,
So I understand the op's post and your reply.
HE wants to STOP using his factory halogen bulb and intall and HID bulb / ballast.
You want him to buy an aftermarket "ADD-On" hid from Hella.
1. if he follows your recommendation, then he has the factory setup AND the add-on. Since HELLA doesnot make factory replacement headlamps for direct consumer purchases.
2. the op wants to REDUCE his electrical consumption, not increase it.
3. And why Hella??????? Any sealed aftermarket hid system will do the same thing....PIAA for example.
Vekke 10-05-2011 03:27 AM
1. Hella makes also oem headlamps and you can look if they have your lamp. After that you can go to local dealer and ask the price. You can go to your loal dealear also ask them straight. If you want to build your own lamps to replace the current ones Hella has kits to do it also.
2. If he installs HID lamps and ballast kit electrical load would be lower.
3. In Finland Hella is most well known manufacturer. Piaa and other make also similar lamps.
I think in europe you also need to add high pressure lamp washers to the system to make it legal.
What comes to legality most of mods that are discussed here are at least illegal in europe if you go by the book I dont about the states.
mcrews 10-05-2011 07:55 AM
do you have any idea how much money you are talking about?
The reality of your recommendation happening is zero.
I don't understandmaking suggestion that aren't going to happen.
That's the problem with forums. Posters just spill out recomendations that have no application to the poster.
It really requires some thought to post a proper answer.
tollo 10-06-2011 09:11 AM
Some of the head lights are made for both: xenon and halogen. My Astra G has approval for low beam xenon and halogen. Xenon headlight can be done also with reflector (not only projector=lens type).
Nevyn 10-06-2011 10:26 AM
Some cars you can buy the housings from a different vehicle and add in. My Elantra can with a little modding, be retrofit with the projectors/lenses and required ballasts/wiring from an Acura TSX with *relative* ease, for less than $300 US. That's about the only LEGAL way to do in in the USA that I know of.
mcrews 10-06-2011 10:32 AM
tollo,
can you provide a link to that information?
That is like saying " Astra runs on gas or desiel"
redpoint5 10-06-2011 03:17 PM
I have installed an aftermarket HID system on my motorcycle because the OEM halogen was dangerously dim.
1. It is illegal and is annoying to oncoming drivers because the lens was not designed to cutoff the light at the proper level.
2. The retrofit did result in dramatically more usable light, and I feel that I am much safer riding at night and detecting objects in the road sooner. I believe the annoyance I cause other drivers is more than offset by my increased safety.
3. The lights are illegal. I narrowly avoided a ticket by explaining to an officer that my low-beam had died and I was running my HID high-beam as an emergency measure to get home.
mcrews 10-06-2011 04:17 PM
wow......
THat is the most self-centered post I have ever read.
No really.
THe fact that you even thought to post it, much less actually do it......
YOU ARE CHEAP. YOU ARE SELFISH. YOU ARE A FOOL.
Go uot and buy legal hid headlamps.
Oh AND YOU ARE STUPID.
Any effort on your part to actually LEARN about hid would lead you to realize that your instalation is REALLY not providing proper lighting. You just think so because it is 'brighter'
I'm stunned.
redpoint5 10-06-2011 05:52 PM
I rank among the least self-centered, and would happily give most things to the service of others, including my life.
Your post, however, is among the most self-righteous and condescending that I have read.
If you read my posting, you would see that I merely placed the safety of my life at greater importance than the comfort of oncoming drivers.
I only run 1 HID and aim it low. I tested this setup from the perspective of the oncoming driver to verify that it is not causing a dangerous situation.
I do realize my setup is not optimized, but that does not preclude improvement. You are displaying ignorance when you make the claim that I do not have improved visibility and safety with my HID retrofit (which you have not seen for yourself).
It is downright arrogance to insinuate that I know nothing about HID technology and implementation. I have posted nothing that would support this claim.
At the time of my retrofit (9 years ago), I do not believe there were any other options (I looked). I would be surprised if there even is a legal retrofit for F4i projector beam HIDs.
My questions for you:
1. Assuming there are legal and "optimized" retrofit kits available for my application, what is the maximum amount I should be expected to pay for the sake of compliance of law and other driver comfort?
2. Should all things that could negatively impact others environment always be avoided?
3. Is it ever appropriate to break the law? Are there some laws that are acceptable to break under certain circumstances?
Originally Posted by mcrews (Post 264415)
wow......
No really.
I'm stunned.
mcrews 10-06-2011 06:13 PM
your reply reflects just about everything I said.
Instead of acknowledging THE FACT that you admitted to, you want to throw up defections.straw man arguements.
"if only you knew me" wow....get a grip. We do know you, read your first post.
listen to yourself " I have posted nothing that would support this claim." You posted your comments!!!
Light coming uot of an iccorrect housing is NOT improved light. And like most ricers, you are COMPLETELY unaware of the impact of improper nighttime lighting on the eye.
9 yrs. YOu have been doing this 9 years. Do you realize how really stupid and "i have my head in the sand' you sound?
Maybe, I would forgive you if this was 3-4 yrs ago.
But the amount of FACTUAL information available that proves you are uniformed is staggering.
"I aim it low" So you admit that it causes others problems and you admit that you 'sacrifice' because of it.
**********again, self-centered punk*********
Driving is a priviledge.
amazing, really.
you are an admitted liar. To law enforcement no less.
redpoint5 10-06-2011 09:09 PM
Let's take a look at each of your comments individually for the sake of clarity.
How have I misrepresented your position on the subject (which is what a strawman is)?
I don't have to acknowledge what I said, because it's all there plain as day, but I will summarize (acknowledge) what I wrote:
1. The retrofit is illegal
2. The retrofit is annoying to other drivers
3. The light is not properly distributed (not optimized in your words)
4. The retrofit resulted in dramatically more usable light and safety
Please, tell me what I need to admit. I've agreed with most everything you have stated or implied.
Car Analogy:
(more) power coming out of an incorrect transmission is NOT improved power.
Of course, the term "improvement" is subjective, but in general receiving more of a desired output is what we are aiming for.
I don't know any "ricers", so I can't comment on their level of awareness. I did, however, mention in my last post that I considered the impact of lighting on the eye of others. Not only did I consider the impact, but I tested it from their perspective so that I could make an informed decision about what I am doing. This is evidence of an individual who is concerned with others.
Fortunately for me, I do not require forgiveness of anyone, but what am I uninformed of? I am pleading to be enlightened, but instead I am receiving mostly ad hominems.
As in all things of life, sacrifice for the sake of bringing about balance is a necessity.
amazing, really.
I see more ad hominems and a regurgitation of a line from the DMV Handbook, but no answer to my questions. This makes my understanding of where you are coming from impossible.
Is there any better kind of liar than the admitted kind? It's the people who will not admit to being a liar you must be most weary of, but I digress...
I have lied to law enforcement on multiple occasions (although I don't know how lying to them is significant compared with lying to anyone else). In this case though, my low-beam was indeed out, and I was using my high-beams to make my way home. I did omit the fact that my low-beam is also an HID, but the LEOs never had a problem with it before. As long as it's not aimed in their faces, they don't seem to care. Had I been asked if my low-beam was HID, I would have replied in the affirmative.
Would now be an inappropriate time to also admit to having illegal license plate, turn signal, and brake lights?
Is it also inappropriate to bring up this admission from mcrews' own profile:
FALL 2010:
2002 Q45 Sport w/ IMPUL body kit, 2005 Headlamps blackedout w/ Advanced Automotive Concepts Halos.
1. You drive an aesthetically altered Japanese import (ricer?)
2. You have blackout headlamps. Illegal in most states including CA.
3. Are halos DOT approved? I think not.
Pointing out hypocrisy does not invalidate a claim, but it does make you question the motives and values of the person making the claim.
redpoint5 10-06-2011 09:46 PM
The eyeball mutilator in full mutilation mode (high and low-beam).
http://i7.photobucket.com/albums/y26...%20Bikes/1.jpg
Normal half-mutilation mode (low-beam).
http://i7.photobucket.com/albums/y26...%20Bikes/4.jpg
I can now see further than 30ft ahead, and can see the road shoulder, but what do I know about improved visibility?!?
http://i7.photobucket.com/albums/y26...%20Bikes/2.jpg
and finally, an admitted liar and Worst-Person-In-the-Worrrld
http://i7.photobucket.com/albums/y26...Picture022.jpg
I hope my posts have helped nobody, since I don't care about others. :rolleyes::D
