High Compression Low Octane
I recently got a 2012 Ford Fiesta (2 year lease) and it has a 1.6L 4cyl engine with a quite high compression ratio, 11:1. A few months ago I got a repair manual for my old car that I'm selling, 97 Chrysler Sebring Convertible. It has a 2.5L V6 with a compression ratio of 9.4:1. There is a side note in the manual that CR a little above 9:1 usually requires premium gas to operate correctly, the Sebring gets away with 87 octane due to timing adjustment and other stuff.
In the owner's manual for my new Fiesta there are 2 sections about gas, 1 says 87 octane is the minimum, while the other says it's the recommmended gas. Since it has such a high CR, I was wondering if there would be any benefit to using higher octane gas. I know higher octane would have anywhere from absolutely none to no benefit in my Sebring, but considering the Fiesta has such a high CR, maybe the timing and other stuff would be adjusted by the car's computer to use the higher octane. I calculated the benefit and with gas at about $4.34/gal the 91 octane would have be about 5% more efficient that 87, with a 20 cent difference in price and originally getting either 30 or 33mpg. Unfortunately my Ultraguage was stolen :mad: so I can't use it to see the actual timing advance with the different octanes, will just have to use avg mpg. I'm just curious that if one works should the reverse: hi CR - hi octane needed - low octane used = less power/efficiency hi CR - low octane needed - hi octane used = ? The dealer gave me a full tank of gas when I got my car and got 30 mpg on that. I'm going to use 2 tanks of Shell 87 octane (almost done with the 1st) then try 1 on 91, see if there is a noticeable difference with similar driving styles. |
Different cars react differently to high octane gas. It makes no difference what gas I put in my Matrix, so I go with the lowest octane. The best way to find out is to try it, so it looks like you are on the right track.
...they (Ford) are playing with the valve-timing so as to vary the effective-CR (which is functional combination of static-CR & dynamic-CR) as engine load and speed change.
Both camshafts can be controlled independently on the Fiesta with throttle by wire and electronic timing control. My last tank in my Fiesta was 47 MPG on cheap Wal Mart gas ($3.409 a gallon). My gauge read 51 when I refilled. I tried 91 octane 0 alcohol gas and got about 2-3 MPG better per tank average, but it cost $4.199 a gallon. When the regular was $3.909 a gallon 6 weeks ago the difference in mileage just about covered the difference in cost, but now that regular E10 has dropped to the point where the difference is 70 cents a gallon it is not even close.
The difference in technology between the Fiesta and your old Chrysler is like the difference in the first us jet, the P80 and a F15. Look at the new SKYACTIV tech from Mazda to see the next step in engine technology. regards Mech |
As an example, I think the new Subaru FA20 (on the BRZ/FRS, and some variant will appear in the new WRX) the intake cam seems to have a volumetric efficiency peak in the 6000s rpm, so it's very possible that the actual cam duration is longer than the cam duration on a Prius for example. |
it may also have to do with most newer cylinder heads having a spherical-ish, non-protruding combustion chamber
reminds me of "l heads" of the flat head fords 6.0:1cr on 87(i think?; wasn't born) vs. lead fuel of the 60's 10:1 or more; vs 80' 8.0-9.0:1 cr |
Green Car Congress: Details on Nissan
This gives you some ideas about high compression ratio with 13 to 1 and supercharging in a 3 cyl 1.2 liter engine. regards Mech |
Good read.
EGR reduces "knock"
although if you have too much overlap then you end up with a lot of fresh, hot exhaust trapped in the cylinder and you have a knock problem.
those "hot gases" are inert and do not support combustion , they reduce combustion pressure and by so doing reduce Combustion Temperature they absolutely do not cause "ping" or "knock" they reduce it they effectively reduce engine displacement by diluting the available combustion chamber size with inert gases , creating a kinda of a cushion of a compressible gas that does not combust inside the combustion chamber they are EGR having said that cooler temperature EGR is better than hotter temperature EGR for the reduction of NOX |
