High Idle after EOC
When a jump start the car after EOC my idle sits at 1500 and doesn't come back for several minutes neglecting and gains from doing EOC. Any ideas on how I can stop my idle from doing this?
Car is a 2000 Nissan Altima. |
Rig an injector kill switch to kill the engine without powering-down the ECM? Just a thought..
Thanks, moving next month will wait till then to try it. Let you know how it works.
When I tried turning the key off and back on my fiero acting about the same way, I did the injector kill switch and when I bump start it now it idles normal. Good luck!
