EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   Honda Asymmetrical Wheel Hole Pattern; Why? (https://ecomodder.com/forum/showthread.php/honda-asymmetrical-wheel-hole-pattern-why-14836.html)
Rokeby 10-11-2010 12:24 PM
2 Attachment(s)
I was looking closely at the aero details on a Honda Fit yesterday.
When I looked closely at the wheels, I could hardly believe what I saw:
Ten large holes on one side, nine smaller ones on the other.
Irregular spacing of the smaller holes too: (Click to enlarge.)
Attachment 7025
Attachment 7026
Why is the hole pattern in the steel wheels asymmetrical?
The wheel is covered by a wheel cover, so I doubt it is directly aero related.
To reduce wind noise created by the wheel spinning?
To minimize structural resonance in the wheel itself?
If the latter, what about the untold millions of symmetrically holed steel
wheels on the road?
:confused:
Somewhat related thread: Why do most wheels have 5 spokes?
The devil is in the details. :rolleyes:
NeilBlanchard 10-11-2010 12:31 PM
That is pretty odd -- where is the valve stem? I can't think that is could relate to balance -- are all four wheels this way?
Rokeby 10-11-2010 01:00 PM
I only looked at the two wheels on the drivers side. I don't know for sure,
but presume they were the same on the pax side.
(Folks don't like it when you prowl around their car, and look at it closely for
a longish time. They think you're scoping it out for a break in. Don't ask me
how I know. That time the security guard did buy my "Just looking at aero
details, Sir." story. :o
"Move along now." )
I think it was a 2010, it was very shiny with no chips or scratches... yet.
I poked all 'round the 'Net -- official Honda sites, Fit sites, etc -- looking for
info on this and have found none. The pix are of wheels for sale from the
'Net though.
Apparently, there have been many different wheels on the different levels of
the Fit over the years, many of them alloy. There have been other steelies
that have symetrical holes. This is allegedly on a Fit: (Pix from the 'Net.)
http://img26.imageshack.us/img26/4358/wintertire.jpg
The earlier pix were taken from the inside/backside of the wheel.
I guess the hole for the valve stem is in the cylindrical rim itself,
on the other side of the perforated disk.
(In the picture above, the valve is at 6 o'clock.)
That's all that I know at this point.
Could the asymmetrical hole pattern have something to do with
breaking up/randomizing the airflow through the wheel and minimizing
the turbulence downstream of the wheel wells?
The wheel cover had a five spoke arrangement, and the hole pattern roughly
divides the wheel in half. I guess you could get three or five different hole
arrangements/net hole areas in the five wheel cover openings.
If this is the reason, would it hurt or help aero to take the wheel covers off?
Inquiring minds are bebaffled, bebothered, and bewildered. :confused:
Frank Lee 10-11-2010 04:28 PM
Interesting.
All I know is, you see asymetric blades on alternator fans for noise reduction...
miket 10-12-2010 01:35 AM
Studies have shown brake rotors with 31 37 or 41 cooling vanes are quieter and smoother than non prime number vaned rotors.
NeilBlanchard 10-12-2010 09:54 AM
Prime numbers are going to greatly diminish the even (and odd?) order harmonics, which are harsher on our ears.
hamsterpower 10-12-2010 11:12 AM
My guess is to balance the tire pressure sensor mounted at the valve stem.
wdb 10-12-2010 11:54 AM
Ditto that, plus the prime number noise thing just because it sounds so plausible. :thumbup:
The second picture, with symmetric holes, looks like a generic rim - something one would purchase to mount winter tires for example.
CapriRacer 10-12-2010 01:26 PM
Must be for wind noise.
NeilBlanchard 10-18-2010 01:35 PM
My brother's 2010 Fit has these asymmetrical wheels, too. Still no closer to knowing why -- to vary the air flow through to the brakes? I wonder if the rims are out of balance -- it would not make sense if they were?
