honda automatic to manumatic question
hi, new member from scotland uk here. im just wondering if anybody on the site has successfully modified there auto transmission to shift manually (specifically hondas). ive read a lot of info here on manumatic conversion and solenoid switching. just wondering if theres anybody who has found any other modifications that can be done and/or there experience with these type of modifications.
thanks. |
If it's controlled by solenoids, it's possible ... with a bit of work. However, you're still going to have the inefficient torque converter, that, when unlocked is going to use up a lot of energy. Even manually locking it would require some more work (and would definitely set a check engine light) .. and require a lot more work to "shift" the manumatic.
had a quick look but they dont seem to have full manual control over the up and down shift
If you're in Europe, why don't you get a manual transmission and adapt an automatic clutch setup like the ones used by disabled drivers? At least it's easier to get those back there than in America...
That's right.
I've seen successful conversion of Jeep Cherokee's automatic gearbox to "manumatic" with converter lockup on demand. It worked great, but ECU was very simple. Newer cars can throw a code when gearbox will miss a shifting point. So my suggestion is to not mess anything up permanently. Just leave GCU working until you'll be sure that your setup is working fine in all conditions.
I think that can be done, and you gave me a subject to think of. Maybe someday I'll try to convert my wife's car to manumatic. |
i know its possible and have seen a few dsm (our equivalent to Mitsubishi think) owners doing this and it would be great so get some definitive info specifically on hondas as im sure alot of people would benefit. as mentioned above if there are electronic safety features built into the car programming then over riding things could create problems. only one way to find out.... lol.
