If it's controlled by solenoids, it's possible ... with a bit of work. However, you're still going to have the inefficient torque converter, that, when unlocked is going to use up a lot of energy. Even manually locking it would require some more work (and would definitely set a check engine light) .. and require a lot more work to "shift" the manumatic.
