Honda CBR600F2 conversion
7 Attachment(s)
Picked up the cbr today. Thinking of renaming my cat Peter Fonda:D. Its a '94 with just under 25k miles on the clock. Some damage to the right side fairing as it had been stolen at one stage.
Plan is to use 2 nissan 48v forklift traction motors for series - parallel setup. Minimum of 72v possibly go to 96. Controller will be my own custom igbt version of the open revolt. Not sure about the charger but the petrol tank is plenty big to accomodate a low power version of the open source charger by Simon Rafferty. Batteries will either be Odyssey pc680 agms or headway 16ah. Thats the basic plan anyway. Now i've never even sat on much less owned a bike until today so like in that film wild hogs its a case of "all the gear , no idea!":thumbup: So first question. Can someone please tell me how to put this thing on its center stand ?? :D:D |
6 Attachment(s)
I took the motors to a local engineering works last week and had the coms turned and the splined shafts turned down to 19mm. Saturday morning I set about milling a 6mm keyway into the shafts. Nightmare job. The shafts are glass hard:mad:. Got there in the end so i'm into scraping out the com segments and replacing the brushes.
There's always some sort of tail grab on the bike... you don't need to stomp on the center stand at all.
Put your right foot on the center stand pad, and the bike will balance itself on the center stand. Lift up and pull slightly back on the left clip-on bar, and the bike will easily lift up on the stand. When I was 100lbs or so, I was doing this with a 600lb bike loaded with gear. It takes nothing but technique. |
I've seen it happen plenty of times... :thumbup: |
Well got her on the stand. A biker friend called in this evening and found the stand had broken and been rewelded incorrectly at some point. Some gentle adjustment with a crowbar got it working perfect. That said it take a good bit of energy to get it on the stand. Perhaps that why a lot of bikers are big and hairy :):)
The effort required may have been due to the "ruined" center stand. |
