Honda Civic for new car?
So I have been thinking a lot since my accident last month, and I just can't find any Toyota Corolla's/Echo's in my area that are under 5k, at least not without having over 100k miles... I seem to be finding a lot of 98-2003 civics that are under 100k miles, clean title, and 4k or under. Would this be good for a new car? I'm being careful to look for any signs of the car being 'riced' and just want some extra input. I looked at fuelly and some other mpg sites and see that those years are only rated for 33mpg highway, what are some real numbers I would be looking at? My Camry was rated for 27 and I got 33 out of it consecutively. Also I'm buying automatic, not manual.
Here is one I found, I'll update with more as I find them. I don't like the aftermarket air intake on it, and will probably mod that to make it a warm air intake, but only 71.8k miles for 4k isn't bad: 1998 Honda Civic LX (green) Here is another: 2004 honda civic 104k auto Here is the criteria I'm looking under if anyone wants to help me look because tbh, I have no idea what I'm looking for. Nothing over 110k miles please: inland empire all for sale / wanted classifieds "honda civic automatic" - craigslist |
Well, I've got a bit of a love-hate relationship going on with my 7th gen ('01-'05) Civic.
7th gens are prone to tranny failures. Autos are worse, but even manual trannies often get input shaft bearing failures. They also commonly get headgasket failures. I've now had both to deal with (as well as some other small issues like motor mount failures). The 6th gens ('96-'00) seem to be more robust and I would probably lean towards one of those if I were to buy a Civic again. |
I have a soft spot for the 96-00 Civics.
Check for a crack in the exhaust manifold, right around the top-front oxygen sensor. It's right on top in front so it's easy to see. Not to bad to fix either - I think I paid ~150 for my new one and a few hours of work (rusty bolts were the worst part). An automatic will get better highway mileage for normal drivers, but a manual allows much more in local driving. |
Timing belts are always a concern. While most people only worry about the miles (it's due every 90k miles) age is also a concern, according to the manual, every six years, IIRC. Documented proof is important. If it's never been done, I would replace it immediately as it's 15 years old now... What model? HX, CX, DX/LX? HX should be best for mileage, EX and Si worst. |
Can't speak for the automatic as mine was a manual, but everything else in my '97 Civic DX was fine with over 225k miles. Engine burned a little oil, likely the valve guides from what I've read. Solid economy car. Check for rust, as that will have better chances of killing it than miles/time.
The 2001 to 2005's are pretty decent. But, like Darcane said, they can have head gasket issues, manual and auto trans issues. My input bearing makes a little noise. I might replace it whenever I change the clutch out. So maybe in 10,000-200,000 miles...
Headgaskets are hit and miss. I am getting low 40's with a manual transmission. I am not doing very well at hypermiling either (not using my kill switch or P&G)! |
So, uh, yeah, do not use a hammer on your car if you can avoid it. To check the manifold, detach the cable to the oxygen sensor, pull the two 12mm bolts, and slide the heat shield down the cable. If it is cracked, I recommend an offset oxygen sensor wrench, I tried a normal one and it seemed to want to damage wires on a very expensive component. If you do need to remove the oxygen sensor, be sure to hit it with PB Blaster! :) There is a local place with a used exhaust manifold for $150, although someone recommended a welder, who would hopefully charge much less. Car-part.com is great for finding parts, but I would also check Craigslist, and I just discovered frugalmechanic.com, which compares different sites and shows available discounts. It showed this aftermarket part: Amazon.com: ATP 101122 Exhaust Manifold: Automotive The comments indicate that the metal is thinner than stock, but that should be fine, the original one is very thick. If you want a new one from Honda, this might be the best price: CONVERTER, MANIFOLD - $496.11 $500 plus shipping. I think that I have already given too much advice that may or may not be useful! :) Quote:
If it is an HX or EX, it has an aluminum oil pan, which are prone to stripping. Again, everybody says to have a "professional" change my oil, but when that is a kid with an impact wrench, pans get stripped. I would recommend going wherever changed the oil last, if they do vehicle inspections, have them check out the car, and then, if everything is in order, have them change the oil. Had I done that with my HX, I might not have needed to change the pan. Finally, everybody recommends Fumoto Valve | Qwik Valve™ |
Here is the car I am talking about. I should have enough money by the end of next week to get it if he still has it. Also guys you are talking way out of my league, could someone show me an engine and circle where I need to check for the crack?
Redlands, Honda CIVIC 99 Low Mileage, Excellent Condition Also trust me, I know exactly what you guys mean about the timing belt, timing belt broke on my dads truck, moms car and my old camry that I used to drive all in the same month, both the truck and car burned valves, luckily when it broke on the camry, it was idling. On yet ANOTHER note, what model is that civic? I don't see any branding on the back whatsoever, and he doesn't have it listed. |
- no tachometer.
- hand crank windows. - black side mirrors. these say DX to me - body color door handles. - body color panel around rear license plate. - body color door trim accent line - it has a center console armrest but these say LX Edit: Ah-ha! I hadn't considered the VP trim. It's basically between DX and LX in features, and introduced in 1998. My year, 1996, didn't have that option. I think this is a VP. Mechanically it's the same as the DX and LX. |
The lack of a RPM gauge is the only beef I have with this car, but for 5k,no way can I pass that up, I'll just put a SG2 or ultragauge, haven't decided yet, and monitor rpm's with that.
Oh also, this will get decent mpg right? Think I could achieve 40mpg with careful driving? |
Functionally, the SG2 and Ultragauge are pretty similar but the Ultragauge is cheaper... I'm happy with my Ultragauge. And I'd guess 40mpg will be an upper limit for a set-it-and-forget-it approach with that automatic. High 30's will be more likely. |
So I talked to the guy, he is going to hold it for me until I can get the money on Thursday yay!!
There are just 2 questions I have for you guys here on the forums, I know this is the VP model so it doesn't have cruise control, would it be possible for me to install Cruise at a later time? I'm not sure if this is possible but it's a big thing for me. Second, Ultragauge WILL work with this right? This is another big thing, it will make or break the sale. Third: Does anyone know anyone on these forums with this car? I would like to know the best mods for this car to decrease Aero and find out what kinda mpg I will be looking at. |
If you want a tach, you can swap out the cluster. I think I paid about $70 for the CR-V cluster I put in my Civic (CR-V cluster is orange instead of blue, which I liked). Swap was easy as can be. I prefer analog tachs to digital like the SGII or Ultragauge. The digital ones have a little lag.
You can add cruise. My Civic didn't have it either, but my dad installed an aftermarket cruise when he owned it before me. I think it was $300-400. Ultragauge will work with it. I personally wouldn't buy a SGII for it. SGII is only worth it for hybrids and other vehicles that make use of the X-gauges. As darcane and Pale have said, it'll get the same MPG as the DX and LX. Just remember that most of the Civics on here are manual. With your mainly highway driving, 35MPG should be doable stock. |
As for basic mods, what are some of the easy ones for this model? I'm kind of curious what can be done to increase MPG right off the bat. |
I would be very skeptical on these low mileage cars. $5k is a lot of money for a 6th gen Civic. Low mileage doesn't always mean it's in good condition. I would rather buy a car with 150,000 miles that has been driven on the highway than one with 60,000 that has made nothing but short trips over it's lifespan. Make sure you check out the service history. The seller claims it has been maintained well, so they should have records to prove it. And make sure they have owned it for several years. Whenever I see someone that says "need to sell ASAP" it makes me nervous.
Guys I'm legit confused... My Camry is only rated for 26mpg highway, and I get 33 with it highway consecutively, should I be able to get 7-9mpg more then what the EPA rating are for with this civic? That would put me at 39-42mpg... I know every car behaves differently but still... Also, it's 0.8L smaller engine, I have a hard time believing that it's only going to get me 3-4 more mpg driving the same way I do now.
I have another question :(... Sorry for all the questions, would it be possible to replace the stock LED's in the cluster with green ones somehow? I would love to have the whole green look going on as I think it would look awesome! (screetches like a little girl). |
Comparing the Camrys and Civics on Fuelly in those years, the Camry averages about 25MPG and the Civic is 31-32MPG. This isn't taking different trannies and trim levels into account, but I think it would be safe to say that mid-high 30's would be doable in a auto Civic.
For the LEDs, I don't think using green ones would make much difference for the blue parts. You might be able get a different colored overlay. I would check out Civic forums for more info. |
Why not a Civic with twice as many miles?
The way I see it, the two biggest obstacles are that you want a car with low miles and an automatic. Low miles isn't necessarily better, especially in a car that's 10+ years old. Low miles generally means it wasn't used often, either for short trips or only occasionally for long trips. That can be brutal for some of the fluids. A manual tranny will generally get you better MPGs, especially if you're hypermiling (though your mostly highway driving may negate that advantage). They also tend to be low maintenance, and cheap when they do need fixed. I think you said something about having a bad back in another thread, making it painful to push the clutch, but have you tried it? With your commute, it looks like you would drive around 20k miles a year. At 40MPG, that's 500 gallons. A quick search shows that gas prices are over $4 a gallon in your area, so that's at least $2000 a year for gas at current prices. At the 33MPG your Camry got, that would be over $2400 a year. So keep that in mind when looking at the money spent now vs later. The best way to reduce your costs would be shortening your commute, either by moving closer or getting a job that's closer. Dunno how viable either of those are, but remember that commuting by car is pretty expensive and a cut in pay/increase in living costs may balance out a shorter commute. |
For the record VSkid, thank you for your help, I'm sorry if it seems im shooting everything you say down but I'm really not. |
What's the issue with a G1 Insight?
The one I just bought (5 speed, 83k miles, 2000) was 5k, and a friend just bought one (2005 with 133k, 5 speed) 5.5k. These are on the pricier end- although a CVT will be lower than a standard MPG wise, not much else comes close. |
You could flip the on off switch and make it gas only. It's pretty simple, I would have taken some pictures when I did an Insight IMA swap last night. Pull up the rug, take out two 10mm bolts, red cap, flip the switch.
On the highway it would probably be more efficient without the battery, to be honest. They're heavy. EDIT: There is a LITTLE more to it, please check post below. |
Also, I want to make a point, I would be perfectly happy to see 40MPG (with whatever car I do get) so anything over that is just pawsome. [Edit]: I did find this one, but the question is, why would he rebuilt the CVT at only 130k miles? Do they go out that fast? http://www.autotrader.com/cars-for-s...71008788&Log=0 |
Hybrid Automotive - Honda Insight (2000-2006) Battery Bypass Instructions
It takes a few minutes. 15 at most. We did two IMA battery swaps last night, and it took maybe an hour and a half- in the dark with one light. |
So in a Prius of Fusion, one can use the all electric system to drive. In a G1 Insight, one uses the 3 cylinder engine: unless they want more power, and then they get Assist from an Integrated Motor :thumbup: No power is weak on hills, but it should not have an affect on highway AT ALL, but city it will affect. No stop start, no boost (IMA helping on take off), less get up and go torque. Even the people who do the engine swaps for the Insights (for racing/autocross) seem to see 40+. |
My friend bought her GORGEOUS 2005 w/130k for 5.5k. It looked fantastic, new brakes and rear shocks, premium sound in it. Everything together and a good battery. I'll be honest, I was a little jelly. I found 4 that are .5k under your goal for initial price, and 5 at or below the price of that Civic. Keep in mind, autotrader prices are inflated by at least 10%. Sometimes they are almost 2 times higher.
Look for Insights at dealers. They usually have no clue what is there, and the resources to get underneath, read codes, so on. It depends on worth it. A red sun beat 2000 with mix matched panels, not stock and worn tires, not even rims, missing underbody panels, bad battery, and throwing codes- not really. A 2006 in Midnight with brand new RE92s, everything there and attached, no issues- a lot more. |
I am not saying don't get a Civic! The Insight is just so overbuilt, and a great car if one has a matching lifestyle (it's only a two seater, can get stares because of the look, regardless of what some may say-it is not a sports car).
I just want to make sure you keep this included with your search. The utility is surprising in it. I have hauled lumber and lots of building materials in it. It hasn't beaten my Mustang in utility, but I now use an Insight as my workhorse and commuter. |
So for 300$ more, I can get car that will get almost double the mpg, nicer looks (I love the way the insight looks tbh) well taken care of, and already has cruise control, rpm gauge and an aftermarket stereo eliminating about 1-1.2k work I was gonna have to do on the civic... |
It sounds nice.
I move slower. I do a LOT of research and work to figure out what I want, and how I want it. I don't go to look at something unless I want it, and I have a set price. I bring x dollars that I am willing to spend. I examine, and make my mental price. My offer is a balance of what work I need to do, and the value. I can wiggle depending on the situation, but I don't go to look if I am not willing to walk away. I'll drive 3 states or take a plane just to turn around and walk away- which is why I do it so rarely! lol |
I think that Civics and especially Echos exceed at cheap and cheerful, with their utility level.
Where the Insight fails at interior space, seating, excessive power, it makes up for in design and technology. But other than the XL1, nothing compares to the G1 Insight. All things being equal, solo/two people, and just driving, the Insight is top dog. |
Oh also, I got my camry up and running again, it runs extremely well, it just took 6 hours of some bending, hammering and pulling to get the trunk to close and back right tail light to be working again. So again, i have another 'utlility' car so to speak. |
I hope others chime in- I don't want to be the sole person saying go G1!
I chimed in so it wouldn't be forgotten, but as you more so describe your personal situation, it seems like it is the way to go. Hope all goes well, and you do have IC.N for a resource. I use it for learning and guides, but prefer the community here. |
