which honda civics meet these criteria
4door sedan
5spd epa: 40+mpg 98 or newer Budget $6,000 |
262 results in the United States.
Find Your Car: Honda Civic Listings Near Cleveland, OH 44129 - AutoTrader.com |
Civic Hybrid is the only 4 door that I know of that gets over 40mpg and it's old enough now that it a 2003 civic hybrid blue books for $3,500
Between seeing Team Honda, and my Mustang approaching 40, I am pretty sure any Honda can do it lol
If you drive smart, you should be able to achieve 40+ with just about any 4 cylinder Honda sedan. I have a 1994 1.6L Honda Del Sol Si 5 speed, it has probably the worst aerodynamics of any Honda car and it is also paired with the shortest (most sporty) gears that Honda offered then (that I know of). I have achieved 40+mpg with it by only having an EOC switch and changing my driving habits. I am 100% positive that you can achieve the same or better results with a newer, longer geared, more aerodynamic 1998+ sedan.
EDIT: Check craigslist in your area, there are tons of them. http://grandrapids.craigslist.org/se...inAsk=&maxAsk= |
But OP did not specify if he wants to stomp the gas pedal and get 40 mpg, or drive smart and/or ecomod to get 40 mpg. Since he is here on ecomodder, I imagine driving smarter/modding are not out of the question-otherwise he would have asked in a Honda forum. Like shortie said, any Honda sedan that meets his criteria is a 40+ mpg car. |
03-05 Civic Hybrid is the only one with 40+ epa rating and stickshift. You don't want that one. By now the batteries are failing and Honda isn't interested in replacing them.
Honda likes to short-change their manuals with higher-revving gear ratios. Still, any recent Civic stick will easily do 40+ mpg, just not epa rated as such. I mean, set the cruise control at 65 and you'll get it. |
I'm now enjoying an average of 52 mpg over the last 20k miles in a good sized 4 door car and a mostly in-town commute. Buy a 2003-2005 Civic hybrid manual with a bad battery: $3500 Buy a new hybrid battery from Bumblebee: $2100 Gets you in under your budget and well over your target. Sam |
