Honda is developing a variable compression automobile engine: MPG up 7.4%
Source: Green Car Congress: Concept: Honda RD Developing Variable Compression Ratio Engine with Dual Piston Mechanism
SAAB did one many years ago but it seemed to me to be really complex.
There is a Veedubber in Cali that made an experimental one in his garage like a decade ago
ok... correction, has been working on it for a Decade in his garage LOL
Amazing Engine, Amazing Pizza! at TimboTrip.com |
Anyone have any images of the principle of the idea?
I could see this being easy on a two stroke type engine just having the head with a moving part in it that would take up some combustion chamber, but with valves in the way.... |
Frank: didn't SAAB's use a movable head somehow?
rkcarguy: no image, but a pretty good description from the GCC article: Quote:
I do remember hearing about the SAAB engine a long time ago. Here is a link:
http://www.saabnet.com/tsn/press/000318p.html Glad to see the issue being revisited. 7.4% is nothing to sneeze at. |
Description works for me metrompg. Looks like it's VTEC pistons:)
VTEC activates a solenoid which pressurizes the pivot point of a 2nd set of rockers under a larger cam lobe, pretty ingenious. |
I could see valve timing be used to increase and decrease "trapped" compression
VTEC for pistons - good analogy!
