EcoModder.com
-   -   Hot Air Intakes.. (https://ecomodder.com/forum/showthread.php/hot-air-intakes-7602.html)
Chris D. 03-26-2009 12:03 AM
Hot Air Intakes..
If you have a scangauge and a hot air intake, what is your outside tempuature as well as your incomming air temps? (read from MAP sensor)
I'm building a hot air intake and would love to see some pictures of everyones setups..
I'd attach my pics for archiving purposes but the
file size limit is too tiny to make it worth while..:(
cfg83 03-26-2009 12:28 AM
Chris D. -
It varies based on the weather and traffic, but with my HAI setup and grill block, it's almost always over 120 degrees F. Today on the freeway, with an outside average temp of 70+ degrees F, I was able to average over 130 degrees F. I think it was even higher, maybe 140+, but I forgot to watch it closely today, :mad: .
If I can find some time this weekend I will take it out and take some pictures.
If you can make your JPEG just under 100K, then you can upload it without being rejected. I can change the JPEG compression using Paint Shop Pro, so I mess with the compression until my chosen image is just under 100K.
CarloSW2
tasdrouille 03-26-2009 07:35 AM
Here's mine for the elantra.
http://ecomodder.com/forum/attachmen...6&d=1205960276
http://ecomodder.com/forum/attachmen...4&d=1205960075
Seeing 50 to 80 F over outside temps with 80% blocked front grille.
vtec-e 03-26-2009 04:14 PM
Thats a nice HAI.
Drive Stick 03-26-2009 04:16 PM
I just posted about mine actually, outside is 46° today, intake at idle was 140° and @ 2,000 rpms it was 126° off-load.
I used a temp sensor on my digital multimeter it's somewhat accurate. See thread for photos
_ Brett
Chris D. 03-27-2009 12:36 AM
1 Attachment(s)
Originally Posted by cfg83 (Post 94221)
Chris D. -
CarloSW2
I was able to upload the same exact pictures on my
other forum that has a limit of 97.7 KB for jpeg pictures.. :confused:
I believe they have their upload setup to auto resize automatically no matter what the size..
Chris D. 03-27-2009 12:49 AM
ok, heres what I've got so far..
heres the stock setup..
http://i4.photobucket.com/albums/y10...5eliminate.jpg
new intake tract setup I chose to use to make room near the manifold..
I used the tubing from a K&N Intake setup..
It wasn't intended to use the factory airbox..
heat gun, dremel, ect.. ;)
http://i4.photobucket.com/albums/y10...e/P1070893.jpg
http://i4.photobucket.com/albums/y10...e/P1070895.jpg
http://i4.photobucket.com/albums/y10...e/P1070896.jpg
This is a deck plate lid.. they use these on boats..
It has a water tight screw in cap that I've left open..
for now it sucks in under hood air with a grill block..
I shoved a rag in the opposite side of the airbox where the cold air came from through the fender..
http://i4.photobucket.com/albums/y10...e/P1070897.jpg
I'd love to figure out a setup so I can switch back to cold
air (on the fly) so i don't detionate if I need to get on it..
I'm still workin on this, not completly finished yet..
What I'd like to see are peoples results in tempuature and what
the outside tempuature was at the time your intakes temp was measured...
heres pictures of how I installed the deck plate..
http://i4.photobucket.com/albums/y10...e/P1070805.jpg
http://i4.photobucket.com/albums/y10...e/P1070806.jpg
http://i4.photobucket.com/albums/y10...e/P1070807.jpg
I also cut some of the stock intake on the cold side to make a little more room
http://i4.photobucket.com/albums/y10...e/P1070808.jpg
http://i4.photobucket.com/albums/y10...e/P1070813.jpg
skuffed it up.
http://i4.photobucket.com/albums/y10...e/P1070815.jpg
washed it out.
http://i4.photobucket.com/albums/y10...e/P1070814.jpg
epoxy
http://i4.photobucket.com/albums/y10...e/P1070817.jpg
screwed/glued ;)
http://i4.photobucket.com/albums/y10...e/P1070818.jpg
inside view with cover in..
http://i4.photobucket.com/albums/y10...e/P1070812.jpg
finished setup..
http://i4.photobucket.com/albums/y10...e/P1070811.jpg
http://i4.photobucket.com/albums/y10...e/P1070810.jpg
so that little 3" tube was clogged up with a rag as you've
already seen to put it in perspective in the engine compartment
tasdrouille 03-27-2009 06:58 AM
Very nice Chris, it doesn't get much simpler than that when you want something you can turn on and off at will.
Chris D. 03-28-2009 12:17 AM
I'd like to have a setup that'll switch from hot to cold air
intake with the flip of a switch or due to a lack in vacuum..
I remember talks of using a volvo air box but nothig came of it on the thread.
JoJotheTireMan 03-30-2009 08:18 AM
That is exactly how mine is setup, hooked to manifold vacuum. Low vacuum equals CAI and high vacuum equals WAI/HAI. A3 (1993-1999) VW 2.0L air box has dual inlets and a vacuum controlled flapper to switch back and forth.
