How to 3800 powersteering delete
1 Attachment(s)
So I recently unhooked the power steering in my lesabre and here's how I did it
I got the parts from napa Parts needed Shorter serpentine belt p.n. 25-060670 90mm tensioner pulley p.n. 38007 The belt is a tight fit and has to be because the tensioner will be about at the end of its travel hence the larger pulley. What I did was to keep most of the stock routing except instead of the belt going from the water pump to the belt goes straight to the alternator Attachment 15386 |
How does it feel with the power steering disconnected?
who needs power steering when you're in nebraska, i dont know if ive even needed the steering wheel going through.
on a less sarcastic note, my '94 olds 88 was awful, largely due to strut mounts hanging up |
How did you know the part for the new shorter belt? Did you measure it or use the part from a model not equipped with power steering?
I measured then found a belt that was the right size I have no idea what vehicle its actualy for. Its a bit of work to steer but I still have the lines hooked up to the pump
