How to Bypass Alternator with a Switch DIY
Hi,
I recently performed this on my 92 Previa and thought it would be a helpful write up. Part one: How to Bypass Alternator with a Switch Part two: Add a Solar Array for Trickle Charging The first part of this project was to replace the existing starting battery with a deep cycle battery. I decided to go ahead with this project now because my starting battery was dying anyways, and because of that, it is a fairly cheap mod. Some people use 2 batteries though. I will try one for now, due to my short commutes and other tricks up my sleeve. The next step is to turn the alternator on and off. Listen up, this is very important! You can not simply disconnect the alternator from the battery. The alternator will continue to output power and will blow up.:eek: “Automotive alternators require a voltage regulator which operates by modulating the small field current in order to produce a constant voltage at the battery terminals.” – Wikipedia So, by disrupting the Field Circuit, we stop power output even thought the alternator is still spinning. And, because the field in no longer complete, there is no resistance that the alternator has to over come via the engine. http://www.ubergreenart.com/watching...rcuit-wire.jpg I confirmed that I had the correct wire (B/O) by running the van and checking the voltage at the battery. It was only 12.5 , so I knew the alternator was not producing and charge. Had it been charging the multimeter would have read ~14.5 volts. The engine ran smoother also. Next, I installed:
This finishes the alternator control circuit. I can keep tabs on the battery with a volt meter. I also posted an image of a relay diagram that I found. I will post the solar installation when the parts come. :turtle: I hope this helps some one. http://www.ubergreenart.com/watching...2/altfield.jpg http://www.ubergreenart.com/watching...2/altrelay.jpg http://www.ubergreenart.com/watching.../altswitch.jpg http://www.ubergreenart.com/watching.../02/vmeter.jpg http://www.ubergreenart.com/watching...ay-diagram.gif |
Nice! And I like the concise discussion of the field wire and the reason for disrupting it. When you ran the wire for the switch, how did you go through the fire wall?
Nice write up.
My 2 cents. The 40A relay and 20A fuse are major overkill. When I did mine I just added a switch (no relay). IIRC the field wire carried less than 1A through it. Here is my setup: http://ecomodder.com/forum/showthrea...tml#post109942 |
^^ 1A? I read the current can get up to 4A :O Maybe that's wrong though.
So if a switch is attached to the brake and gas so that whenever the engine is under very light load or when the car is decelerating, that would be a very weak sort of regenerative braking. Basically collect electrical energy when it's cheap/free from the engine. I think BMW is doing this in new cars. Since these switches would be modulated a lot a relay might be a good idea. |
I measured something low around 1A when I measured mine. In any case you can get away with just a switch. Mine has been installed for over a year now and works great. However a relay definitely does allow you to do some nifty things like activate it while braking. Also, if you use a normally closed relay it will fail in the closed position so if it does fail your alternator is connected.
